Please check config (1811)
rygar1234
Hi guys can you check this config please. It's working ok but if there are any improvements I can do or you see any mistakes let me know please.
I put 20 track 20 on the 69.x.x.x ip to give the 70.x.x.x priority is that correct ?
ip route 0.0.0.0 0.0.0.0 FastEthernet0 70.x.x.x track 10
ip route 0.0.0.0 0.0.0.0 FastEthernet1 69.x.x.x 20 track 20
The only issue which might be by design is that I cannot sent email or browse any sites through the 69.x.x.x ip unless the 70.x.x.x is down (failover) is it because I give priority to the 70.x.x.x ip?
Thank you!
guruprasadr
Level 7
Level 7
HI, [Pls RATE if HELPS]
Can you add the below command feature in your IP SLA Configuration:
track object-number rtr rtr-operation {state | reachability}
Example:
Router(config)# track 123 rtr 1 reachability
Tracks the state of a Cisco IOS IP SLAs operation and enters tracking configuration mode.
For more informative. Refer the Useful link below:
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
