combining rip and static routing using ospf ?
garytan231
hello guys please enlighten me i am really confuse right now regarding my school assignment , my teacher told us to combine these rip and static routings using ospf routing with separate router is it possible or not ?, thank you
24 Replies 24
do i need to connect my five routers to the third party router like what you did ?
Not at all...
Like your previous post it should be perfect.
Best regards
hello sir can you review from what i've done there ?
Hello @garytan231
No problem, yes!
Please attache your new zip file.
Best regards
here you go
thanks @garytan231
Here in attached zip file
Redistribution on R1 routers under their respective ospf process.
Best regards
so does this mean pc under router 3 on rip topology can ping to pc under router 4 topology ?, thank you
Yes @garytan231 it should be.
Ensure to have unique subnet attached to each Routers on your topology.
Best regards
i have unique subnets attached on all of my routers but still my pc under every router on static topology can't ping to pc under every router on rip topology
is it like this ?
