L2TPV3 over IPSEC bridging
bdecout
I'm trying to bridge a VLan using L2TPV3 over IPSEC.
Everything is working properly when the computers have an MTU manually lowered to 1300. But it doesn't work for computers with default MTU.
The show L2tp session all shows no packets being dropped because of MTU so it seems that it is the IPSEC encapsulation that is making the packets too big.
I've tried using IP TCP ADJUST-MSS as well as lowering the MTU on the router interfaces but it doesn't help.
Cisco bug CSCek46765 mention a problem with LT2PV3 over GRE which could be the one I'm hitting here but the workaround of using IP MTU 1538 doesn't work for me as loopback interfaces can't be set with an MTU that big.
Is anybody successfully running LT2PV3 over IPSEC. What did you do to fix the MTU issue?
8 Replies 8
bdecout
Problem solved.
"IP PMTU" command had to be removed from the pseudowire-class.
Removing that command will mean that you will see fragmentation - meaning traffic will get process-switched leading to high CPU load on your device. Did you ever experience this? If so did you solve the problem another way?
I ask because we see the same problem. We need 'ip pmtu' to stop CPU problems but at the same time we can't have it because it breaks some servers! Catch-22.
Marcin Zgola
Level 4
Level 4
can you email me a copy of your config?
I am trying to do same thing
thanks
CCIE 18676
pseudowire-class vlan-xconnect
encapsulation l2tpv3
ip local interface Loopback1
ip tos reflect
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr aes 256
group 5
crypto isakmp key xxx address 12.55.144.12
crypto ipsec transform-set ESP-AES256-SHA esp-aes 256 esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to 12.55.144.12
set peer 12.55.144.12
set transform-set ESP-AES256-SHA
match address 100
interface Null0
no ip unreachables
interface Loopback1
description L2TPv3 Tunnel Source
ip address 172.20.20.251 255.255.255.255
ip mtu 1420
ip tcp adjust-mss 1300
interface FastEthernet0
description $ETH-LAN$$FW_OUTSIDE$
ip address 24.x.x.215 255.255.255.240
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
interface Vlan1
no ip address
ip mtu 1400
xconnect 172.20.20.250 1 pw-class vlan-xconnect
ip route 0.0.0.0 0.0.x.x.155.121.209
access-list 102 permit ahp host 12.55.144.12 host 24.155.121.215
access-list 102 permit esp host 12.55.144.12 host 24.155.121.215
access-list 102 permit udp host 12.55.144.12 host 24.155.121.215 eq isakmp
access-list 102 permit udp host 12.55.144.12 host 24.155.121.215 eq non500-isakmp
access-list 102 remark IPSec Rule
access-list 102 permit ip host 172.20.20.250 host 172.20.20.251
access-list 102 deny ip any any log
hmm.
Ok, I am not sure if i am asking to much, but how this VLAN tunneling excatly works? Can you email me configuration on both ends?
Here is what I am trying to do:
SW1 (3VLANS) --- Router --- IPSEC/VPN --- ROUTER --- (3VLANS) --- SW2
When you look at this. I want Sw1, and sw2 to share same VLANid and broadcast domain.
Is this possible?
CCIE 18676
The other end is exactly the same config , just reverse the IP adresses.
First establish your IPSEC tunnel.
When you can ping the loopback IP from each side, apply the xconnect and pseudo-wire class.
What you want to do is possible , however this config will only let you share a single Vlan.
praetoleiad
hi,
has this been resolved? i am facing this concern also.
newbieregarded
Would you still be able to add an IP address to VLAN 1?
