command for checking SVI Interfaces created on L3 switch
ambivert skill
Hi ,
Please let me know the command by which I can check all SVI Interface that I have created on L3 Switch.
L3#show ip int bri will be the only command by which we can see the VLAN Interfaces with assigned IP address (SVI Int.) can be seen
cadet alain
you already mentioned one command, what other information do you want to see ?
Alain
Thanks Cadet for your reply just want to know if there any command also exist beside this one.
Ambivert Skill
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
You should also see your SVI if you issue the different show interface commands, such as show int summary.
