Checking on QoS
billmatthews
We have a router that does bandwidth limiting outbound:
class TAG-AF22
  set dscp af22
  bandwidth remaining percent 15
And inbound policing...
class QOS-TEST
  set dscp a11
  police cir 768000
   conform-action transmit
   exceed-action drop
Is there a way to show if these thresholds are ever being hit?  For example of QOS-TEST or TAG-AF22 were ever throttled?
Bill
2 Accepted Solutions
Hello
on the interfaces these policies are applied
int xx
serivice-policy in/output xxxx
show policy-map int xx
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
But for congestion on the class TAG-AF22 where would I look?  Is it the total drops?
Depends on how you define congestion.  Total drops records the number of times the queue overflowed; a result of congestion.
Queue depth shows packets currently queued, and when count is more than zero, you have congestion.
Hello
int xx
res
paul
Kind Regards
Paul
Thanks, +5, that's what I was looking for.  From the output I can see the CIR restrictions...
      police:
          cir 768000 bps, bc 24000 bytes
        conformed 43034439 packets, 21546043234 bytes; actions:
          transmit
        exceeded 1303684 packets, 1848827178 bytes; actions:
          drop
    Class-map: TAG-AF22 (match-any)
      56393724 packets, 39300308195 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/163818/0
      (pkts output/bytes output) 56229899/39112431711
      QoS Set
        dscp af22
          Packets marked 56393724
      bandwidth remaining 15% (264 kbps)
Bill
Disclaimer
Posting
Thank you both!
