Command to get the channel of wireless AP
cole xu
Hello
Could you tell me how to know which channel is being used by a wireless AP with the CLI interface ?
Note: dot11radio interface is configured to be 'channel least-congested'
Thanks !
Show controller dot11 X/Y
5 Replies 5
Leo Laohoo
Commands are "dot11 dot11 carrier busy test"
Results should come out in the "sh logs".
Thanks for your quick response. I tried as your suggestions, but didn't get what I need.
From below output , I can not know what is the current channel.
>show log
Frequency  Carrier Busy %
   2412          3
   2417          1
   2422          3
   2427          2
   2432          3
   2437          0
   2442          5
   2447          1
   2452          3
   2457          1
   2462          1
   2467          1
   2472          0
I can get what I need from web page, as attached file shows, but can not get the information using command lines. So still need your help. Thanks!
I tried, and can get the information I need. Thank you all !
Current Frequency: 2457 MHz  Channel 10
Allowed Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 244
7(8) 2452(9) 2457(10) 2462(11) 2467(12) 2472(13)
Listen Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 2447
(8) 2452(9) 2457(10) 2462(11) 2467(12) 2472(13) 2484(14)
Thanks for the nice rating and good luck!
