Command to install Port License in ASR1001-HX
robinsinghal271
I want to install a Port License in ASR1001-HX but not getting the proper documents to install it.
License Install
command is not able to work. Pls help.
Robin
@robinsinghal271 wrote:
interface_1g                 (ASR_1000_HX_1GE_2P)                 2 IN USE
interface_10g               (ASR_1000_HX_10GE_2P)               2 IN USE
Cisco Smart License has cleared the router to enable both the 1- and 10 Gbps ports.
Now, what "port license" are you wishing to enable?
8 Replies 8
balaji.bandi
which IOS version are you running ? Keep in mind that starting with 16.10, smart licensing is mandatory.
https://www.youtube.com/watch?v=47Tflbt4NEc
robinsinghal271
Thanks for quick response.
Pls find below the details of "show version"
Router#show version
Cisco IOS XE Software, Version 17.06.03a
Cisco IOS Software [Bengaluru], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-
M), Version 17.6.3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Fri 08-Apr-22 04:50 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2022 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 16.3(2r)
Router uptime is 2 minutes
Uptime for this control processor is 5 minutes
System returned to ROM by IntelResetRequest
System image file is "bootflash:asr1000-universalk9.17.06.03a.SPA.bin"
Last reload reason: IntelResetRequest
States and local country laws governing
import, export, transfer
and
third-party authority to
import, export, distribute or use encryption
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Type: Smart License is permanent
License Level: adventerprise
Next reload license Level: adventerprise
The current crypto throughput level is 0 kbps
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco ASR1001-HX (1SR) processor (revision 1SR) with 3742322K/6147K bytes of mem
ory.
Router operating mode: Autonomous
Crypto Hardware Module present
8 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
29401087K bytes of eUSB flash at bootflash:.
@Georg Pauwen  I am using IOS version 17.06.03a. Smart license is also enabled.
@balaji.bandi I have already checked that document but it is helpful with
show
commands. I need commands to install the port license.
Robin
robinsinghal271
Please help me with the solution.
Robin
The router is already on 17.X.X so this means Cisco Smart License is enabled.  This also means the command
license install
is no longer supported.
Please post the complete output to the command
sh license summary
Hi Leo,
Please find below the output.
Router#sh license summary
License Usage:
License                        Entitlement Tag                               Count Status
adventerprise                (ASR_1000_AdvEnterprise)              1 IN USE
advipservices                (ASR_1000_AdvIpservices)              1 IN USE
That's all I found with this command.
Robin
Thanks @Leo Laohoo
I was not aware with this concept. Thank you so much for the clearance.
Robin
