command to see dropped packets on ISR router
D@1984
Is it a similar command for ISR router; like show asp drop on ASA, to see the dropped packets? I have some asymmetric routing issues and trying to capture the dropped packets.
I think they introduced the 'show drops' command in XE starting with version 17.8.1., unlikely that you have that on your ISR...
https://www.cisco.com/c/en/us/td/docs/routers/C8000V/Troubleshooting/troubleshooting-guide-for-cisco-catalyst-8000v-edge-software/m_debug-packet-drops.pdf
no, I dont have that command.
there are two type of drop
silent and non-silent drop
as I know any drop because asym or l2 issue is silent i.e. there is no counter count these drop.
what you can do
using permit ACL with Log
using debug
but notice both effect the CPU, it can cause high CPU utilize.
