VRF routing
Ragavi
Frequent Visitor
Frequent Visitor
Hi All,
We are working on Multidomain routing
I want two different ip of same subnet (int fa0/1 -192.168.10.0/24 - CE end) to communicate with two different VRF (cust1 and Cust3), please help me with the configuration
Path should be:
192.168.10.10 -> 10.0.11.5 (Cust1) -> 192.168.40.10 (Blue line) = Vice versa
192.168.10.11 --> 10.0.13.44 (Cust3) --> 192.168.30.10 (Red line) = Vice versa
Configuration:
hostname CE1
ip vrf Cust1
rd 64903:11
route-target export 64903:11
route-target import 64903:11
ip vrf Cust3
rd 64903:22
route-target export 64903:22
route-target import 64903:22
interface Loopback0
ip address 10.0.14.5 255.255.255.255
interface Loopback1
ip vrf forwarding Cust1
ip address 10.0.12.6 255.255.255.255
interface Loopback2
ip vrf forwarding Cust3
ip address 10.0.12.8 255.255.255.255
interface FastEthernet0/0.1
description Link to PE1 FA0/0
encapsulation dot1Q 100
ip address 10.0.11.5 255.255.255.240
standby 1 ip 10.0.11.3
standby 1 timers 1 3
standby 1 priority 110
standby 1 preempt
interface FastEthernet0/0.3
description Link to PE5 FA0/0
encapsulation dot1Q 300
ip address 10.0.13.41 255.255.255.240
standby 3 ip 10.0.13.43
standby 3 timers 1 3
standby 3 priority 110
standby 3 preempt
interface FastEthernet0/1
ip address 192.168.10.1 255.255.255.0
speed auto
duplex auto
interface FastEthernet3/0
ip address 10.0.69.113 255.255.255.248
duplex full
router bgp 64903
bgp router-id 10.0.14.5
bgp log-neighbor-changes
neighbor 10.0.69.114 remote-as 64903
address-family ipv4
network 10.0.112.0 mask 255.255.255.248
neighbor 10.0.69.114 activate
neighbor 10.0.69.114 next-hop-self
neighbor 10.0.69.114 soft-reconfiguration inbound
exit-address-family
address-family ipv4 vrf Cust1
bgp router-id 10.0.11.3
network 10.0.11.0 mask 255.255.255.248
network 192.168.10.10 mask 255.255.255.255
redistribute connected
neighbor 10.0.11.1 remote-as 4637
neighbor 10.0.11.1 transport connection-mode passive
neighbor 10.0.11.1 timers 1 3
neighbor 10.0.11.1 activate
neighbor 10.0.11.1 next-hop-self
neighbor 10.0.11.1 soft-reconfiguration inbound
exit-address-family
address-family ipv4 vrf Cust3
bgp router-id 10.0.13.43
network 10.0.13.40 mask 255.255.255.248
network 192.168.10.11 mask 255.255.255.255
network 192.168.30.0
neighbor 10.0.13.44 remote-as 64909
neighbor 10.0.13.44 transport connection-mode passive
neighbor 10.0.13.44 timers 1 3
neighbor 10.0.13.44 activate
neighbor 10.0.13.44 next-hop-self
neighbor 10.0.13.44 soft-reconfiguration inbound
exit-address-family
attached topology for your reference:
mlund
Level 11
Level 11
This can probably be done different ways. First, because the 192.168.10.0 is in global space, you have to do route leaking between customers and global, both ways. It's a little bit tricky, because setting next hop can be hard. Different routers/code behave different. You have to play around with that to see if you can get it to work. Also, in bgp, to announce a route, the exact route has to be in the routing table. In your config is "network 192.168.10.10 mask 255.255.255.255" to announce that route it has to be a route in the vrf that match that. It can not be /24 mask it must be a /32.
Second way is easier. Move the int fa0/1 to a common vrf. In that new vrf import and export both cust1 and cust2. And make an access-list on the interface that only allowed the traffic you want.
/Mikael
you must use import/export to leak the prefix from one VRF to other.
