Commands related to IOS Interface detail
boyer
I may be trying to compare apples to oranges but when I run a show interfaces serial 1/0 from my own router I get the following output, which shows a problem I'm having with input packets:
cisco#show interfaces serial 1/0
Serial1/0 is up, line protocol is up
Hardware is M1T-T3+ pa
Description: "PA-T3+ Serial 1/0"
Internet address is 192.168.0.1
MTU 4470 bytes, BW 44210 Kbit/sec, DLY 200 usec,
reliability 254/255, txload 31/255, rxload 123/255
Encapsulation PPP, LCP Open
Open: IPCP, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d01h
Input queue: 0/600/0/224 (size/max/drops/flushes); Total output drops: 456008
Queueing strategy: fifo
Output queue: 0/600 (size/max)
5 minute input rate 21434000 bits/sec, 2615 packets/sec
5 minute output rate 5528000 bits/sec, 2308 packets/sec
196662654 packets input, 665052509 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 parity
2162023 input errors, 2137254 CRC, 0 frame, 17207 overrun, 30 ignored, 7562 abort
169695963 packets output, 4241150293 bytes, 0 underruns
0 output errors, 0 applique, 3 interface resets
30 unknown protocol drops
1006 carrier transitions
rxLOS inactive, rxLOF inactive, rxAIS inactive
txAIS inactive, rxRAI inactive, txRAI inactive
When I ask the ATT tech person to run this from the other side the output is different
show interfaces t3-2/3/0:4
Physical interface: t3-2/3/0:4, Enabled, Physical link is Up
  Interface index: 896, SNMP ifIndex: 1605
  Link-level type: PPP, MTU: 4474, Clocking: Internal, Speed: T3, Loopback: None, FCS: 16, Mode: C/Bit parity, Parent: coc1-2/3/0:4 Interface index 895
  Device flags   : Present Running
  Interface flags: Point-To-Point SNMP-Traps Internal: 0x4000
  Link flags     : Keepalives
  Keepalive settings: Interval 10 seconds, Up-count 1, Down-count 3
  Keepalive: Input: 8980 (00:00:05 ago), Output: 9237 (00:00:08 ago)
  LCP state: Opened
  NCP state: inet: Opened, inet6: Not-configured, iso: Not-configured, mpls: Not-configured
  CHAP state: Closed
  PAP state: Closed
  CoS queues     : 8 supported, 8 maximum usable queues
  Last flapped   : 2019-10-24 20:06:47 UTC (23:37:40 ago)
  Input rate     : 2880096 bps (1478 pps)
  Output rate    : 16160016 bps (1967 pps)
  Active alarms  : None
  Active defects : None
  Logical interface t3-2/3/0:4.0 (Index 74) (SNMP ifIndex 1606)
    Description: MNX
    Flags: Point-To-Point SNMP-Traps 0x4000 Encapsulation: PPP
    Bandwidth: 44210kbps
    Protocol inet, MTU: 4470
      Flags: No-Redirects, Sendbcast-pkt-to-re
      Addresses, Flags: Is-Preferred Is-Primary
        Destination: 192.168.0.0/30, Local: 192.168.0.2, Broadcast: 192.168.0.3/30
Interface               Admin Link Proto    Local                 Remote
t3-2/3/0:4.0            up    up   inet     192.168.0.1/30
 19:26-current:
    LCV: 0, PCV: 0, CCV: 0, LES: 0, PES: 0, PSES: 0, CES: 0, CSES: 0, SEFS: 0, UAS: 0
  19:11-19:26:
  18:56-19:11:
  18:41-18:56:
  18:26-18:41:
  18:11-18:26:
  17:56-18:11:
  17:41-17:56:
  17:26-17:41:
  17:11-17:26:
  16:56-17:11:
  16:41-16:56:
Oct 24 14:32:27  ipsin401me3 mib2d[1808]: SNMP_TRAP_LINK_UP: ifIndex 1606, ifAdminStatus up(1), ifOperStatus up(1), ifName t3-2/3/0:4.0
Oct 24 17:54:32  ipsin401me3 mib2d[1808]: SNMP_TRAP_LINK_DOWN: ifIndex 1606, ifAdminStatus up(1), ifOperStatus down(2), ifName t3-2/3/0:4.0
Oct 24 17:55:22  ipsin401me3 mib2d[1808]: SNMP_TRAP_LINK_UP: ifIndex 1606, ifAdminStatus up(1), ifOperStatus up(1), ifName t3-2/3/0:4.0
Oct 24 20:04:37  ipsin401me3 mib2d[1808]: SNMP_TRAP_LINK_DOWN: ifIndex 1606, ifAdminStatus up(1), ifOperStatus down(2), ifName t3-2/3/0:4.0
Oct 24 20:04:41  ipsin401me3 mib2d[1808]: SNMP_TRAP_LINK_UP: ifIndex 1606, ifAdminStatus up(1), ifOperStatus up(1), ifName t3-2/3/0:4.0
Oct 24 20:06:29  ipsin401me3 mib2d[1808]: SNMP_TRAP_LINK_DOWN: ifIndex 1606, ifAdminStatus up(1), ifOperStatus down(2), ifName t3-2/3/0:4.0
Oct 24 20:06:49  ipsin401me3 mib2d[1808]: SNMP_TRAP_LINK_UP: ifIndex 1606, ifAdminStatus up(1), ifOperStatus up(1), ifName t3-2/3/0:4.0
So what I'm not seeing is something like:
from the ATT side router output. Is there a different command to get this extra detail? I'm sorry but I don't know the
version of IOS on the ATT router but I'm guessing its probably somewhat current.
it looks like the AT&T router is a Juniper router, so the output looks different.
That said, CRC and input errors usually point to a physical (cabling) problem...
Leo Laohoo
@boyer wrote:
reliability 254/255
Very indicative of a layer 1 issue.
