common E1 configuration with serial interface 0/0/0 ...
sugar2ferret
hi, can some one help me with this config... im not sure why it dont work.. and what router rip does here? and what ip classless does here?
!This is the running config of the router: 200.x.x.245 (Trinidad)
!version 12.3
no service config
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname OMMITED
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 6
logging buffered 4096 debugging
logging console critical
enable secret xxxx
enable password 7 OMMITED
username cisco privilege 15 secret 5 OMMITED
clock timezone PCTime -7
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
aaa new-model
aaa authentication login local_auth local
aaa session-id common
ip subnet-zero
no ip source-route
no ip gratuitous-arps
ip cef
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
ip name-server 200.x.x.1
login block-for 3 attempts 3 within 3
no ftp-server write-enable
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 200.130.x.x.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no shutdown
speed auto
duplex auto
no mop enabled
interface FastEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no shutdown
speed auto
duplex auto
no mop enabled
interface Serial0/0/0
ip address 200.23.x.x.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no shutdown
router rip
redistribute connected
network 10.0.0.0
network 200.x.x.0
network 200.x.x.0
ip classless
ip route 0.0.0.0 0.x.x.x.23.251.201
ip http server
ip http authentication local
ip access-list extended autosec_complete_bogon
deny ip 0.0.0.0 0.255.255.255 any
deny ip 1.0.0.0 0.255.255.255 any
deny ip 2.0.0.0 0.255.255.255 any
deny ip 5.0.0.0 0.255.255.255 any
deny ip 7.0.0.0 0.255.255.255 any
access lis ommited
permit ip any any
logging trap debugging
logging facility local2
access-list 100 permit udp any any eq bootpc
access-list compiled
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^C
AUTHORIZED USERS ONLY
^C
banner motd ^C EHV-GEM Authorized Use ^C
line con 0
exec-timeout 5 0
login authentication local_auth
transport output telnet
line aux 0
exec-timeout 15 0
line vty 0 4
privilege level 15
password xxx
transport input telnet
line vty 5 15
privilege level 15
password xxx
end
lgijssel
Level 9
Level 9
If this is an E1, I am missing the entries for controller E1:
controller E1 0/0
framing NO-CRC4
channel-group 1 timeslots 1-30 ...
Or something like that.
Leo
mastram4u
what is not working?
Are you running RIP as the routing protocol in the network?
ip classless enables classless routing behaviour in the router
