Communication problem between Cisco 8500-12x and Fortigate
User24571
I have a communication problem between Cisco 8500-12X and Fortigate Firewall.
The problem is that both devices suddenly stopped communicating with each other (they do not respond to ICMP - on FW I allowed ICMP packets) Of course, no other traffic goes through either.
Interestingly, the MAC addresses are refreshing.
On the router I have implemented L2 on bridge-domain.
Topology:
Fortigate (Public IP) ---- (int BDI) Cisco 8500-12X -- ISP
On the router I have recommended software: 17.09.04a
5 Replies 5
M02@rt37
@User24571
Do you diagnose on Fortigate side ? I mean, diagnose sniffer packet in CLI to see if icmp echo-request from C8500 arrived on that FortiGate ?
Best regards
So c8500 use BDI and or L3 interface BVI,
Thr FPR use pppoe?
That correct
If yes then check your routing table in fpr
MHM
balaji.bandi
To make sure what device having this issue-
try below
PC ---- (int BDI) Cisco 8500-12X -- ISP  ( does the PC able to work as expected )
from there you know where to start troubleshooting
BB
User24571
Thank you for all your ideas, but the problem lay elsewhere
It turned out that two Fortigate clusters present themselves with the same MAC address.
is this HA  ? then try turn off one of the node and check ?
BB
