Communication problem
StudentDz
Hello, everyone, I have this scenario where a Cisco 2901 Router configured as following :
Building configuration...
Current configuration : 2428 bytes
! Last configuration change at 15:04:22 UTC Sat Nov 19 2022
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
no ip domain lookup
ip cef
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.16.201.254 255.255.240.0
duplex auto
speed auto
interface GigabitEthernet0/2/0
switchport access vlan 2
no ip address
interface GigabitEthernet0/3/0
no ip address
interface Vlan1
no ip address
interface Vlan2
ip address 192.168.1.254 255.255.255.0
no ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
_________________________________________________________________________________________________
Two Cisco 2960 Series with a configuration as follows :
hostname SW_B
boot-start-marker
boot-end-marker
no ip source-route
no ip gratuitous-arps
ip icmp rate-limit unreachable 1000
vtp mode transparent
udld aggressive
interface Null0
no ip unreachables
interface FastEthernet0/1
description B
switchport access vlan 201
switchport mode access
interface FastEthernet0/11
description B
interface FastEthernet0/12
description B
interface FastEthernet0/13
description B
interface FastEthernet0/14
description B
interface Vlan201
ip address 172.16.201.2 255.255.240.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache cef
no ip route-cache
hostname SW_A
boot-start-marker
boot-end-marker
no ip source-route
udld aggressive
description A
interface FastEthernet0/24
description A
interface Vlan2
ip address 192.168.1.253 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
_________________________________________________________________________________________________A#1-1 : 192.168.1.11    255.255.255.0     Gateway      192.168.1.254
A#1-2 : 192.168.1.12    255.255.255.0     Gateway      192.168.1.254
B#201 : 172.16.201.100    255.255.240    Gateway     172.16.201.254
SVR#201-1 : 172.16.201.101    255.255.240    Gateway     172.16.201.254
SVR#201-2 : 172.16.201.102    255.255.240    Gateway     172.16.201.254
SVR#201-3 : 172.16.201.103    255.255.240    Gateway     172.16.201.254
Question is : why can't I ping from ex A#1-2 to B#201 ? I mean , why both networks A and B can't see each other?
5 Replies 5
this looks like a Packet Tracer project. Post the zipped Packet Tracer project (.pkt) file, as well as any instructions you are following.
Actually, the packet tracer's simulation I just dropped here is working just fine, I just wanted to make you familiar with the topology ; The problem though is in the real situation, I coud not make it happen, I do appreciate your quick response Georg
NetworkDave
@StudentDz,
There are questions between the topology and configuration. As @Georg Pauwen has advised, please provide the zipped pka/pkt file and any instructions you were given.
Yep, I've attached it already, Thanks Dave.
StudentDz
Here you find ZIPPED the .pkt simulation file,
