Cisco 860 Series Routing Help
tnewton-shaw
Good Morning,
I am seeing issues with my newly bought Cisco 867VAE-K9 in that I cannot ping outbound from a device inside the network to outside.
I can verify the following:
  • PPP Details are correct
  • The router can ping outbound from CLI
  • Routing externally is correct
  • DNS is correct
  • DHCP is correct
  • Wireless Module is correct
The device I am using is currently plugged into the GigabitEthernet1 port and has the IP 192.168.1.1 if that is any help.
I have attached the full configuration below (removing all credentials etc). Any help on this would be a life saver!
version 15.3
no service pad
hostname XXX-XXX
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret 5 #####################
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius local
aaa session-id common
wan mode dsl
ip dhcp excluded-address 192.168.1.240 192.168.1.253
ip dhcp pool LAN-DHCP
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
dns-server 8.8.8.8 8.8.4.4
lease 7
ip name-server 8.8.8.8
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
username admin privilege 15 secret 5 ######################
controller VDSL 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface GigabitEthernet0
description LAN Access Port
switchport access vlan 10
no ip address
spanning-tree portfast
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
shutdown
duplex auto
speed auto
interface Wlan-GigabitEthernet0
description XXX-WIFI
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan10
description LAN
ip address 192.168.1.254 255.255.255.0
interface Dialer0
ip address negotiated
ip mtu 1420
ip virtual-reassembly in
encapsulation ppp
ip tcp adjust-mss 1380
dialer pool 1
ppp authentication chap callin
ppp chap hostname xxxxxxx@xxxx.com
ppp chap password 0 ########
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 10
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 Dialer0
dialer-list 1 protocol ip permit
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
access-class 10 in
privilege level 15
transport input ssh
scheduler allocate 60000 1000
end
Many thanks,
Toby
balaji.bandi
From Router console are you able to ping 8.8.8.8 (to make sure ISP Link working) if that is working ad below config :
interface Vlan10
ip nat inside
interface Dialer0
ip nat outside
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 100 interface dialer0 overload
and test it
BB
balaji.bandi
interface Vlan10
ip nat inside
interface Dialer0
ip nat outside
and test it
BB
Balaji I could kiss you - It works thank you so much!
