community - additive and remove ?
mac_mac_net83
Hi All,
When setting community values under a route-map (set extcommunity xxxx) with the "additive" keyword, this prevents the new entry to overwrite the existing entries.
However, is there such similar commands where you want to remove a particular community under the route-map without affecting the other existing communities values. I was hoping there could be similar to " switchport trunk allowed vlan remove x" on the switches.
I tried to remove one entry using " no setextcommunity" and it just removes all other entries.
Mac
Giuseppe Larosa
Hello  Mac,
you should use a standard extcommunity-list to specify the extended community that you want to delete
see
https://www.cisco.com/c/m/en_us/techdoc/dc/reference/cli/nxos/commands/bgp/ip-extcommunity-list.html
ip extcommunity-list standard TEST permit RT:100:100
! note I am note sure you can match using the RT prefix otherwise use only numerical values
Then inside the route-map you should use
set extcommunity TEST delete
The idea is the same as for standard community list as explained in the other post in this thread
Hope to help
Giuseppe
trfinkenstadt
hi, mac,
you can possibly try something like this:
ip community-list expanded remove permit 65000:10000
route-map remove permit 10
set comm-list remove delete
--tim
HI Tim,
Thanks for your comments.
I am referring to communitly list under a route-map.
Example as below:
route-map abcd permit 10
match ip address prefix-list xxxx
set extcommunity 12345:1111 12345:2222 12345:3333 additive
I only want to remove 12345:3333.
When I do the below commands:
no set extcommunity 12345:3333
It will basically remove all the other entries as well. So sometimes, I need to reapply the whole list.
Mac
Giuseppe Larosa
Hello  Mac,
see
Hope to help
Giuseppe
the same with me, apparently you will need to remove all entries first and then adding back all the other entries except for the extcommunity you want to exclude
