Compact Flash Card Compatibility
nathanellis09
I am currently in the process at upgrading my IOS from version 12.2 to 15.0. I had to buy a new CF card (Kingston 16GB) because the one supplied with my 2811 doesn't have enough space (64MB). Does anyone know if the router will support a card as big as 16GB? Or is that too big?
Vinit Jain
I have never tried it but i think 16Gb might not be supported. the supported CF size on 2811 series router is maximum 256 MB.
http://www.cisco.com/c/en/us/td/docs/routers/access/2800/hardware/installation/guide/hw/01_hw.html#wp1037629
Hope this helps.
Vinit
--Vinit
