Showing results forĀ
Search instead forĀ
Did you mean:Ā
VRF-Lite
olly ahmed
Why we use  the command "capability vrf-lite" ?
e.ciollaro
Level 4
Level 4
it's useful when you have OSPF as CE-PE routing protocol. In this scenario if CE has vrf configured, the advertisement from PE are rejected because of DN bit (an MPLS anti-loop technology). If you use vrf capabilities advertisement are not rejected.
Bye,
enrico
PS: rate if useful
it is also needed in "true" VRF-Lite (without BGP/MPLS)  environments with non-backbone internal routers:
CSC Discussion: OSPF NSSA with VRF not working
Rolf
