Compatible IOS in 881
david.robles
I have a Cisco Router 881 with c880data-universalk9-mz.150-1.M7.bin IOS file. I want to upgrade to the latest IOS
c880data-universalk9-mz.152-4.M2.bin. But when I upload the file, it appears the message
The selected file c880data-universalk9-mz.152-4.M2.bin is not compatible with this router model.
Does anyone know what it is because?
Thanks in advance for helping me.
David Robles.
paolo bevilacqua
Please post 'show version' for your router and where the message appears.
Thanks Paolo for your answer. The result for show version is:
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.0(1)M7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Fri 05-Aug-11 02:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
Router_Switch uptime is 9 minutes
System returned to ROM by reload at 23:49:16 MVDO Sat Feb 2 2013
System restarted at 23:56:13 MVDO Sat Feb 2 2013
System image file is "flash:c880data-universalk9-mz.150-1.M7.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 881 (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FTX160788FZ
5 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO881-SEC-K9       FTX160788FZ
License Information for 'c880-data'
    License Level: advsecurity   Type: Permanent
    Next reboot license Level: advsecurity
I use the Cisco Configuration Professional to upload the new file. When I try to upload apears the warning box saying:
The selected file c880data-universalk9-mz.152-4.M2.bin is not compatible with this router model. Do you want to continue copy operation?
Best regards,
David Robles.
Try using CLI.  The command is:  copy tftp:///filename.bin flash:
I can copy the file using CLI, but I am not sure that the file is compatible or not with my router. I have the possibility to copy with CCP, clicking Yes to the question "The selected file c880data-universalk9-mz.152-4.M2.bin is not compatible with this router model. Do you want to continue copy operation?"
