Compress IN NVRAM
hindhabaoui
hi
I have a configuration file of 70KB size but on my router I only 55KB nvram.
is there a way to compress the configuration.
7 Replies 7
paolo bevilacqua
conf t
service compress-config
use the search, these things are easy fo find.
thanks for your reply
I have under question
can I use my carte flash instead of my NVRAM because I have a large file.
if yes tell me how.
thanks.
Try compress first, it's much easier and very effective.
habaoui
I am not sure if it is model dependent or IOS version dependent, but I tested using the compact flash card to store the startup config and it worked well. I was testing on an 1841 running 21.4T.
Rick
Rick
Hi Rburts
can you give me the link or config
thanks
tamerahmedov
Try
1- service compress-config,
2- copy running-config startup-config command
I have done this but the following message appear:
Uncompressed configuration from 52150 bytes to 201331 bytes
