compression
wgranada1
I'm running into a problem here I'm trying to take off compression on a serial interface. I do the "no" form of the command on the remote router but then when I do the same on the local router I can no longer log back into the remoter router. I've done 2 other routers successfully just this one is giving me problems. Any advice would be greatfully appreciated...Here is the config on the remote end:
interface Serial0/0
ip address 172.19.98.198 255.255.255.252
ip accounting output-packets
ip nat inside
encapsulation frame-relay
no ip route-cache
ip ospf network point-to-point
no ip mroute-cache
fair-queue 64 256 0
service-module t1 timeslots 1-8
frame-relay map ip 172.19.98.197 16 broadcast IETF payload-compression FRF9 stac software
frame-relay lmi-type cisco
Thank you in advance
royalblues
Level 10
Level 10
What exact command are you negating..
You only need to remove the compression but you would still require the MAP statement
Narayan
