Config C897VA-K9 for Vodafone Portugal
centrorepair
Hi guys
I have a cisco router C897VA-K9, and i would like to configure it to replace my vodafone Portugal Router.
I have already set almost everything.... but what i'm missing is the way to assing Vlan100 to Port8 (WAN) of the router.
From what i've been reading around the internet, i have to assign vlan100 to the internet port, but everytime i try to use "switchport" command on Port8 (WAN), all i got is that this command does not exist for this port.
Does anyone know how can i configure this router for replacing my Vodafone Portugal one ??
P.S. - I don't have a modem.... the LAN cable comes directly from the ONT.
if there is no authentication, use the simplified configuration below:
Current configuration : 2617 bytes
! Last configuration change at 00:29:32 UTC Thu Jan 21 2021
version 15.6
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4
ip cef
no ipv6 cef
license udi pid C897VA-K9 sn FCZ2030C0MS
redundancy
controller VDSL 0
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
no ip address
duplex auto
speed auto
interface GigabitEthernet8.10
interface GigabitEthernet8.100
description Uplink to Vodafone
encapsulation dot1Q 100
--> ip address dhcp
--> ip nat outside
no ip redirects
no ip proxy-arp
ip virtual-reassembly in
no cdp enable
interface Vlan1
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
--> ip nat inside source list 1 interface GigabitEthernet8.100 overload
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet8.100 dhcp
ipv6 ioam timestamp
--> access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
9 Replies 9
balaji.bandi
try below dot1.Q interface - this example for 101 - change to 100, still issue post complete configuraiton and logs
https://forum.vodafone.co.uk/t5/Archive/cisco-887va-working-with-vodafone/m-p/2585347
BB
thanks for your help, but it didn't work.
My router is a c897va, not an c887... and my connection is not adsl.
i understand that is the example config to give indication of config. Hope you have solved by now other suggestions.
regarding performance, i do not believe this router model support Line speed - the one you expecting. - its limitation of the router.
BB
the below sample configuration should work. Important parts are marked in bold:
ip dhcp excluded-addess 192.168.1.1
ip dhcp pool LAN
--> encapsulation dot1Q 100
no ip redirects
no ip proxy-arp
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface Vlan1
ip nat inside
interface Dialer0
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer-group 1
ppp mtu adaptive
ppp authentication pap chap ms-chap callin
ppp chap hostname X.X.X.X
ppp chap password X.X.X.X
ppp ipcp dns request
ppp ipcp route default
ppp ipcp address accept
no cdp enable
--> ip nat inside source list 1 interface Dialer0 overload
--> dialer-list 1 protocol ip permit
my configuration is as follow :
Building configuration...
version 15.6
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
ip cef
no ipv6 cef
redundancy
controller VDSL 0
interface ATM0
 no ip address
 shutdown
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
interface Ethernet0
 no ip address
 shutdown
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 duplex auto
 speed auto
 no ip redirects
 no ip proxy-arp
 no cdp enable
interface Vlan1
 ip nat inside
interface Dialer0
 mtu 1492
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 no cdp enable
 ppp mtu adaptive
 ppp chap password 0 X.X.X.X
no ip http server
ipv6 ioam timestamp
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
end
One thing i saw on the config you told.... you told me to issue the commands :
but my connection to vodafone portugal does not have any username or password..... it's a fiber connection.
the fiber comes from the outside-->ONT--> Mikrotik Router(this is the one i want to let go.... too slow).
I don't know if the config file from the mikrotik can help.... but here it is :
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 6.48 (c) 1999-2020       http://www.mikrotik.com/
[?]             Gives the list of available commands
command [?]     Gives help on the command and list of arguments
[Tab]           Completes the command/word. If the input is ambiguous,
                a second [Tab] gives possible options
/               Move up to base level
..              Move up one level
/command        Use command at the base level
# jan/10/2021 02:31:08 by RouterOS 6.48
# software id = TMEU-K0JJ
# model = 850Gx2
# serial number = xxxxxxxxxxxx
/interface bridge
add name=bridge1_dhcp
/interface ethernet
set [ find default-name=ether6 ] l2mtu=1582 name=ether1 speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
/interface vlan
add comment=net interface=ether1 name=vlan100_ether1 vlan-id=100
/interface ethernet switch
set 0 switch-all-ports=no
/ip pool
add name=dhcp_pool1 ranges=192.168.1.150-192.168.1.200
/ip dhcp-server
add address-pool=dhcp_pool1 authoritative=after-2sec-delay disabled=no \
    interface=bridge1_dhcp name=dhcp1
/tool user-manager customer
set admin access=\
    own-routers,own-users,own-profiles,own-limits,config-payment-gw
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,passw\
    ord,web,sniff,sensitive,api,romon,dude,tikapp"
/interface bridge port
add bridge=bridge1_dhcp hw=no interface=ether1
add bridge=bridge1_dhcp hw=no interface=ether2
add bridge=bridge1_dhcp hw=no interface=ether3
add bridge=bridge1_dhcp hw=no interface=ether4
add bridge=bridge1_dhcp hw=no interface=ether5
/interface bridge settings
set allow-fast-path=no
/ip neighbor discovery-settings
set discover-interface-list=!dynamic
/interface l2tp-server server
set enabled=yes max-mru=1460 max-mtu=1460
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2 enabled=yes
/ip address
add address=192.168.1.80/24 interface=bridge1_dhcp network=192.168.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add disabled=no interface=vlan100_ether1
/ip dhcp-server network
add address=192.168.1.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.1.80 \
    netmask=24
/ip dns
set allow-remote-requests=yes
/ip firewall address-list
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ip upnp
set enabled=yes
i've removed some sensitive data.....
The Lan cable from the ONT is connected to Lan Port 1 of this mikrotik.
Thanks again for any help provided
version 15.6
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
ip cef
no ipv6 cef
redundancy
controller VDSL 0
interface ATM0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
duplex auto
speed auto
--> ip address dhcp
--> ip nat outside
no ip redirects
no ip proxy-arp
no cdp enable
interface Vlan1
ip nat inside
no ip http server
ipv6 ioam timestamp
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Hi Georg
Thanks for your help....
Thats it..... working..... thanks.
Just one more question.....
My fiber connection is 1Gbps/200Mb.
When running the speedtest by Ookla, i can get around 400Mb~420Mb/200Mb with this cisco router.
I've tried with an Asus Router(RT-AC68U) with the default configuration for replacing the Vodafone Router..... and with this asus router, running the same speedtest by ookla, using the same server, i can get around 900Mb~940Mb/200Mb.
Is there anything i can do to speed up this cisco router.... or is it an hardware limitation ?
Once again.... thank you so much for your help.
don't be scared, but officially the throughput for the 890 series is about 75Mbps, or even less. So if you get roughly 400/200, that is much, much more than can be expected from this router.
