Config Example for VDSL2 High-Speed WIC
I'm looking for a working config example for a Cisco VDSL2 High-Speed WAN Interface Card in a 2901 Router running on IOS 15.0(1)M5.
Does anyone have such information available?
Shawn Munster
This works for Telstra NBN FTTN (VDSL) Australia
You might have to update your IOS to 15.5.
and VDSL Controller firmware.
controller VDSL 0/0/0
 operating mode vdsl2
 firmware filename flash:VA_A_39m_B_38h3_24h_o.bin
Building configuration...
Current configuration : 12208 bytes
! Last configuration change at 14:27:10 PCTime Fri Nov 11 2016 by Shawn
version 15.5
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
aaa new-model
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
ethernet lmi ce
clock timezone PCTime 10 0
no ip source-route
ip port-map user-protocol--2 port udp 3391
ip port-map user-protocol--3 port tcp 3478
ip port-map user-protocol--1 port tcp 3391
ip port-map user-protocol--6 port udp 5062
ip port-map user-protocol--4 port udp 3478
ip port-map user-protocol--5 port tcp 5062
ip dhcp excluded-address 192.168.1.1 192.168.1.49
ip dhcp pool DHCP_POOL
 import all
 network 192.168.1.0 255.255.255.0
 dns-server 139.130.4.4 203.50.2.71
 default-router 192.168.1.1
no ip bootp server
ip name-server 139.130.4.4
ip name-server 203.50.2.71
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-1982477479
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1982477479
 revocation-check none
 rsakeypair TP-self-signed-1982477479
redundancy
no cdp run
ip tcp synwait-time 10
class-map type inspect match-any SDM_BOOTPC
 match access-group name SDM_BOOTPC
class-map type inspect match-all sdm-nat-user-protocol--6-1
 match access-group 102
 match protocol user-protocol--6
class-map type inspect match-all sdm-nat-user-protocol--5-1
 match protocol user-protocol--5
class-map type inspect match-all sdm-nat-user-protocol--4-1
 match protocol user-protocol--4
class-map type inspect match-all sdm-nat-user-protocol--3-1
 match protocol user-protocol--3
class-map type inspect match-all sdm-nat-user-protocol--2-1
 match access-group 101
 match protocol user-protocol--2
class-map type inspect match-all sdm-nat-user-protocol--1-1
 match protocol user-protocol--1
class-map type inspect match-any ccp-skinny-inspect
 match protocol skinny
class-map type inspect match-any sdm-cls-bootps
 match protocol bootps
class-map type inspect match-any ccp-h323nxg-inspect
 match protocol h323-nxg
class-map type inspect match-all sdm-nat-sip-tls-1
 match protocol sip-tls
class-map type inspect match-any ccp-cls-icmp-access
 match protocol icmp
 match protocol tcp
 match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
 match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
 match protocol h323-annexe
class-map type inspect match-any ccp-cls-insp-traffic
 match protocol pptp
 match protocol dns
 match protocol ftp
 match protocol https
 match protocol icmp
 match protocol imap
 match protocol pop3
 match protocol netshow
 match protocol shell
 match protocol realmedia
 match protocol rtsp
 match protocol smtp
 match protocol sql-net
 match protocol streamworks
 match protocol tftp
 match protocol vdolive
 match protocol tcp
 match protocol udp
class-map type inspect match-all SDM_GRE
 match access-group name SDM_GRE
class-map type inspect match-any ccp-h323-inspect
 match protocol h323
class-map type inspect match-all ccp-invalid-src
 match access-group 100
class-map type inspect match-any ccp-sip-inspect
 match protocol sip
class-map type inspect match-all sdm-nat-sip-1
 match protocol sip
class-map type inspect match-all ccp-protocol-http
 match protocol http
class-map type inspect match-any SDM_DHCP_CLIENT_PT
 match class-map SDM_BOOTPC
class-map type inspect match-any CCP_PPTP
 match class-map SDM_GRE
class-map type inspect match-all ccp-insp-traffic
 match class-map ccp-cls-insp-traffic
class-map type inspect match-all ccp-icmp-access
 match class-map ccp-cls-icmp-access
policy-map type inspect ccp-inspect
 class type inspect ccp-invalid-src
  drop log
 class type inspect ccp-protocol-http
  inspect
 class type inspect ccp-insp-traffic
  inspect
 class type inspect ccp-sip-inspect
  inspect
 class type inspect ccp-h323-inspect
  inspect
 class type inspect ccp-h323annexe-inspect
  inspect
 class type inspect ccp-h225ras-inspect
  inspect
 class type inspect ccp-h323nxg-inspect
  inspect
 class type inspect ccp-skinny-inspect
  inspect
policy-map type inspect sdm-pol-NATOutsideToInside-1
 class type inspect sdm-nat-user-protocol--1-1
  inspect
 class type inspect sdm-nat-user-protocol--2-1
  inspect
 class type inspect CCP_PPTP
  pass
 class type inspect sdm-nat-sip-1
  inspect
 class type inspect sdm-nat-user-protocol--3-1
  inspect
 class type inspect sdm-nat-user-protocol--4-1
  inspect
 class type inspect sdm-nat-sip-tls-1
  inspect
 class type inspect sdm-nat-user-protocol--5-1
  inspect
 class type inspect sdm-nat-user-protocol--6-1
  inspect
 class class-default
  drop log
policy-map type inspect ccp-permit
 class type inspect SDM_DHCP_CLIENT_PT
  pass
 class class-default
  drop
policy-map type inspect ccp-permit-icmpreply
 class type inspect sdm-cls-bootps
  pass
 class type inspect ccp-icmp-access
  inspect
 class class-default
  pass
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-self-out source self destination out-zone
 service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
 service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
 service-policy type inspect sdm-pol-NATOutsideToInside-1
interface Null0
 no ip unreachables
interface Embedded-Service-Engine0/0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 shutdown
interface GigabitEthernet0/0
 description $FW_INSIDE$
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
 ip virtual-reassembly in
 zone-member security in-zone
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 shutdown
 duplex auto
 speed auto
 no mop enabled
interface ATM0/0/0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 shutdown
 no atm ilmi-keepalive
interface Ethernet0/0/0
 description $ETH-WAN$$FW_OUTSIDE$
 ip address dhcp client-id Ethernet0/0/0 hostname test.telstra.net
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 zone-member security out-zone
 no mop enabled
interface GigabitEthernet0/3/0
 no ip address
interface GigabitEthernet0/3/1
 no ip address
interface GigabitEthernet0/3/2
 no ip address
interface GigabitEthernet0/3/3
 no ip address
interface GigabitEthernet0/3/4
 no ip address
interface GigabitEthernet0/3/5
 no ip address
interface GigabitEthernet0/3/6
 no ip address
interface GigabitEthernet0/3/7
 no ip address
interface Vlan1
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
ip forward-protocol nd
ip http server
ip http access-class 3
ip http authentication local
ip http secure-server
ip nat portmap VOICE
 cisco-rtp-sip-low
 cisco-rtp-skinny-low
ip nat inside source list 1 interface Ethernet0/0/0 overload
ip nat inside source static tcp 192.168.1.35 3391 interface Ethernet0/0/0 3391
ip nat inside source static udp 192.168.1.35 3391 interface Ethernet0/0/0 3391
ip nat inside source static tcp 192.168.1.29 5060 interface Ethernet0/0/0 5060
ip nat inside source static udp 192.168.1.29 5060 interface Ethernet0/0/0 5060
ip nat inside source static tcp 192.168.1.29 3478 interface Ethernet0/0/0 3478
ip nat inside source static udp 192.168.1.29 3478 interface Ethernet0/0/0 3478
ip nat inside source static tcp 192.168.1.29 5061 interface Ethernet0/0/0 5061
ip nat inside source static udp 192.168.1.29 5061 interface Ethernet0/0/0 5061
ip nat inside source list 110 interface Ethernet0/0/0 overload portmap VOICE
ip nat inside source static tcp 192.168.1.29 5062 interface Ethernet0/0/0 5062
ip nat inside source static udp 192.168.1.29 5062 interface Ethernet0/0/0 5062
ip route 0.0.0.0 0.0.0.0 dhcp
ip access-list extended SDM_BOOTPC
 remark CCP_ACL Category=0
 permit udp any any eq bootpc
ip access-list extended SDM_GRE
 remark CCP_ACL Category=1
 permit gre any any
logging trap debugging
access-list 1 remark INSIDE_IF=lan
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 remark HTTP Access-class list
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 2 deny   any
access-list 3 remark HTTP Access-class list
access-list 3 remark CCP_ACL Category=1
access-list 3 permit 192.168.1.0 0.0.0.255
access-list 3 deny   any
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 192.168.1.35
access-list 102 remark CCP_ACL Category=0
access-list 102 permit ip any host 192.168.1.29
access-list 110 permit udp any any range 16384 16482
access-list 110 permit tcp any any range 16384 16482
access-list 110 permit udp any any range 35000 45000
access-list 110 permit tcp any any range 35000 45000
control-plane
banner login ^CE-Rescue Systems^C
line con 0
 transport output telnet
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login authentication local_authen
 transport input telnet ssh
line vty 5 15
scheduler allocate 20000 1000
end
