09-18-2018 07:27 PM - edited 03-05-2019 10:55 AM
System Description: SF350-48P
System Up Time (days,hour:min:sec): 01,21:54:02
System Contact:
System Name: L2CSOC-NOC
System Location:
System MAC Address: 00:8e:73:32:37:63
System Object ID: 1.3.6.1.4.1.9.6.1.96.48.1
Unit Type
1 SF350-48P
interface FastEthernet4
spanning-tree portfast
switchport mode trunk
switchport access vlan 123 IP Phone not Cisco
switchport trunk native vlan 567 Computer
no macro auto smartport
Explain to me please about why to set Trunk and Access in same interface
Thanks you
09-19-2018 12:37 AM
1) a port configured as trunk expects packets to contain a vlan-id
2) packets not containing a vlan-id/tag are cosidered to belong to the native vlan
3) the access vlan.... command in the configuration is ignored.-> you can remove it
09-19-2018 02:54 AM
I don't think that mentioned configuration is working. If it is working then this is your luck. This may a try to overwrite configuration. Best configuration for Phone and PC is below
switchport trunk native vlan 567 (Copmuter-VLAN)
switchport trunk allowed vlan add 567,123
Voice VLAN-ID 123
Deepak Kumar
