Configuration buffer full error
Ramesh Babu
Dear Friends,
When i am executed wr mem or copy run startup, at the time i am getting following error, kindly assist me how solve this issues,
#copy running-config startup-config
Destination filename [startup-config]?
Building configuration...
% Warning: Saving this config to nvram may corrupt any network management or security files stored at the end of nvram.
Continue? [no]:
% Configuration buffer full, can't add command: vrf xxxx
%Aborting Save. Compress the config, Save it to flash or Free up space on device[OK]
#dir
Directory of flash0:/
1 -rw- 95890300 Oct 2 2015 02:08:36 +09:00 c2900-universalk9-mz.SPA.153-3.M5.bin
2 -rw- 3064 Sep 9 2014 13:32:54 +09:00 cpconfig-29xx.cfg
3 -rw- 80804 Oct 19 2014 02:39:48 +09:00 xxC_NATs.txt
4 drw- 0 Sep 9 2014 13:33:22 +09:00 ccpexp
245 -rw- 2464 Sep 9 2014 13:35:04 +09:00 home.shtml
246 -rw- 99507376 Oct 13 2014 22:54:16 +09:00 c2900-universalk9-mz.SPA.152-4.M7.bin
247 -rw- 2211 Oct 15 2014 22:20:36 +09:00 FTX1837AHNY_201410150616582970.lic
248 -rw- 282575 Oct 25 2016 15:47:34 +09:00 running-config-25-10-2016
256487424 bytes total (58261504 bytes free)
#sh ver
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
System image file is "flash0:c2900-universalk9-mz.SPA.153-3.M5.bin"
Cisco CISCO2921/K9 (revision 1.0) with 483328K/40960K bytes of memory.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
Thanks & Regards,
Ramesh Babu.A.
6 Replies 6
cae_technology
Hi, did you manage to get this working? I got the same problem too....HELP
marce1000
 - Try a reboot, if that does not help , use the latest advisory release (upgrade) ,  could be a software bug :
           https://software.cisco.com/download/home/282774229/type/280805680/release/15.7.3M8
 M.
Thanks, Marce we did upgrade to the gold star 15.5 well the gold version for the 6800 switch and will let you know how i get on.
there used to be the command below:
service compress-config
Check if that is still available...
Georg tried that already but im going to do what Marce advised or go through the config and remove some unnecessary configuration
an even older command used to be 'boot buffersize', not sure if that is still around...
