Configuration on PIX515E
philipsyao
we have a vpn on PIX515E, and now I need to setup another VPN with a outside peer. However, when I configure the PIX, I use the following command:
isakmp key <Keystring> address A.B.C.D [netmask mask]. However, after I type in this, the previous command for the exisiting peer just disappeared. Can the isakmp key command only be used once?
The same thing happened when I use the command: crypto map MapName interface outside.
I really don't know PIX much, thanks for your help in advance.
andrew_ho
You can definitely have multiple isakmp key for different peers. However, you can apply only one crypto map to an interface. But within the single crypto map, you can have different seq no for different policies for different peers.
Cheers,
