Configure 1921 MPLS L2 WAN as bridge mode
Ethan and Mia
Hello ,
Follow the picture I want configure Router_B as bridge mode for WAN MPLS L2
What should i need to do on router B ?  or nothing to do
Leonid Voronkin
For a start you need to understand what is the MPLS L2. Do you really need it? If I correctly understood from your picture you just need DHCP Relay
________________________________________________________
Если ответ понравился, ставь звёздочку. Если ответ помог решить твою проблему, утверди его в качестве решения
Thanks for replay Leonid
I am beginner for Layer 3 . I try to learn by myself . Okay i will learn about DHCP relay , and WAN bridge mode
If you have more suggestion please feel free to tell me
Big Thanks
