Logging Message on Router
Reza_Mohd
I would appreciate if I can get any help regarding stopping the logging message. I did run the command no logging console but even I'm keep getting the same.
Thank you.
Regard
Reza
16 Replies 16
try:
term no mon
Dear Pauwen,
Thank you so much for quick response.
I tried mentioned command before, but still I'm getting the logging message.
Reza
Router(config)#no logging monitor
Otherwise post the full config of your router...
Also, you might have some debugging turned on.
Router#u all
Dear Pauwen,
Unfortunately, I won't be able to post the log now as office already closed.
Will surely send you the logs early morning.
Thank you so much sir.
Reza
Please share the output of "Show logging"
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Deepak,
Here is the show logging:
Cisco4321#show logging
Syslog logging: disabled (0 messages dropped, 2 messages rate-limited, 132 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 168 messages logged, xml disabled,
filtering disabled
Monitor logging: disabled
Buffer logging: level debugging, 36 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level debugging, 39 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (4096 bytes):
*Nov 3 07:28:32.590: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Nov 3 07:28:34.135: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = ipbasek9
*Nov 3 07:28:35.318: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 50000 kbps
*Nov 3 07:28:36.443: %IOSXE_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Nov 3 07:28:39.920: dev_pluggable_optics_selftest attribute table internally inconsistent @ 0x144
*Nov 3 07:28:43.603: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Nov 3 07:28:44.454: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Nov 3 07:28:44.454: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Nov 3 07:28:44.454: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Nov 3 07:28:44.462: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Nov 3 07:28:45.789: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Nov 3 07:28:45.840: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Nov 3 07:28:45.840: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Nov 3 07:28:45.840: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Nov 3 07:28:45.841: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Nov 3 07:28:45.841: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Nov 3 07:28:47.109: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Nov 3 07:28:47.114: %SPA_OIR-6-OFFLINECARD: SPA (ISR4321-2x1GE) offline in subslot 0/0
*Nov 3 07:28:47.119: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Nov 3 07:28:47.119: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Nov 3 07:28:47.120: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Nov 3 07:28:47.120: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Nov 3 07:28:47.154: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Nov 3 07:28:47.195: %SPA-3-ENVMON_NOT_MONITORED: SIP0: iomd: Environmental monitoring is not enabled for ISR4321-2x1GE[0/0]
*Nov 3 07:28:51.910: %SPA_OIR-6-ONLINECARD: SPA (ISR4321-2x1GE) online in subslot 0/0
*Nov 3 07:28:53.863: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Nov 3 07:28:53.904: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Nov 3 07:29:12.846: %LINK-5-CHANGED: Interface GigabitEthernet0/0/0, changed state to administratively down
*Nov 3 07:29:12.846: %LINK-5-CHANGED: Interface GigabitEthernet0/0/1, changed state to administratively down
*Nov 3 07:29:12.846: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Nov 3 07:29:12.882: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
*Nov 3 07:29:16.277: %SYS-5-RESTART: System restarted --
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
*Nov 3 07:29:18.783: %SYS-6-BOOTTIME: Time taken to reboot after reload = 6007325 seconds
*Nov 3 07:30:09.444: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Nov 3 07:30:14.563: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Nov 3 07:36:49.401: %SYS-5-LOGGING_STOP: Logging disabled - CLI initiated
Cisco4321#
Type a command
"no logging console"
Deepak Kumar
Deepak Kumar,
Hi Deepak,
Still I'm getting the logging message:
Cisco4321(config)#no logging con
%FMANFP-6-IPACCESSLOGP: SIP0: fman_fp_image: list 121 permitted tcp 141.145.10.140(19995) -> 202.123.25.226(25), 1 packets
Cisco4321(config)#no logging console
%SYS-5-LOG_CONFIG_CHANGE: Console logging disabledFIU-Cisco4321(config)#
Cisco4321(config)#
Cisco4321(config)#
Cisco4321(config)#do wr
Building configuration...
[OK]
Cisco4321(config)#exit
SYS-5-CONFIG_I: Configured from console by consoleFIU-Cisco4321#
Cisco4321#
%FMANFP-6-IPACCESSLOGP: SIP0: fman_fp_image: list 121 permitted tcp 40.107.2.47(33192) -> 202.123.25.226(25), 1 packet
Cisco4321#
How do you log in the device? Is it Telnet/SSH or Local Console?
Deepak Kumar
Deepak Kumar,
HI Deepak,
I'm login on the device through local console.
Reza
Please share an output"Show IP access-list"
It's looking like a bug in the IOS and also confirms the current ISO Version.
Deepak Kumar
Deepak Kumar,
As per shared logs, it looks like that you have configured one extended ACL"121" with the log or log-input keywords in the ACL.
Is it correct? If yes then please remove those keyboard from the end of ACL or update device.
Deepak Kumar
Deepak Kumar,
Cisco4321#
Cisco4321#
Cisco4321#
%FMANFP-6-IPACCESSLOGP: SIP0: fman_fp_image: list 121 permitted tcp 81.12.78.250(12099) -> 202.123.25.226(80), 116 packets
%FMANFP-6-IPACCESSLOGP: SIP0: fman_fp_image: list 121 permitted tcp 206.229.236.45(31474) -> 202.123.25.226(25), 170 packets
%FMANFP-6-IPACCESSLOGP: SIP0: fman_fp_image: list 121 permitted tcp 40.107.5.85(30976) -> 202.123.25.226(25), 1 packet
%FMANFP-6-IPACCESSLOGP: SIP0: fman_fp_image: list 121 permitted tcp 157.150.240.17(62139) -> 202.123.25.226(25), 206 packets
%FMANFP-6-IPACCESSLOGP: SIP0: fman_fp_image: list 121 permitted tcp 40.107.7.83(61072) -> 202.123.25.226(25), 283 packets
Cisco4321#
%FMANFP-6-IPACCESSLOGP: SIP0: fman_fp_image: list 121 permitted tcp 40.107.6.47(26114) -> 202.123.25.226(25), 1 packet
Cisco4321#
