Configure 2821 router for redundancy
ccaldwell1
Can someone suggest the best redundancy options for this router. Customer mentioned they need gig-E port with AS number configured..
sorry for if this seems like a dump queston, but its OJT.
Thanks.
bbxie
Level 3
Level 3
Not sure what redundancy you are talking about with GE/AS number. However 2821 has two integrated 10/100/1000 ethernet port, definately you can have two ethernet connection to 2821, and you can configure dynamic routing protocol to support routing redundancy. you can also configure HSRP with another router to provide redundancy. there is a built in external power-supply connector that eases the addition of external redundant power supply that can be shared with other Cisco products to decrease network downtime by protecting the network components from downtime due to power failures
