Configure 3G wireless as a backup line with layer 3 cisco switch??
Fida jlassi
Hi all,
We have an existing GPRS modems to tranfer data between 2 different sites, This connection is a little bit slow at no more than about 114kbps, the idea is to add a 3G modem, so the solution will be based on a dual communication lines which are the 3G network and GPRS network.
The GPRS line will be the primary and the 3G will be secondary, This redundancy will offer a high level of communication availability between both sites.
is it possible to configure this redundancy with a cisco switch layer 3? if it's the case did you have a tutorial or a link that describe how to do this work with a layer 3 ciso switch?
any information will be helpful for me, thanks
31 Replies 31
Is  it possible to use the RV042 instead of the SF300 switch in this case  and according to the architecture that I posted above, to do the WAN  balancing (the WAN balancing will be done according to the Bandwidth).
Jalssi Fida
Can anyone answer the question above, Thanks.
jlassi Fida
