dot1G . I have a problem
saomarcos
There is my configuration. I have only access with subnetwork 192.168.10.254 in the internet. With others can not ping de gateways example: 192.168.20.254 , 192.168.30.254 and 192.168.40.254.
Help me please.
Building configuration...
Current configuration : 3057 bytes
! Last configuration change at 12:09:50 UTC Fri Nov 22 2013
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 25
dot11 syslog
ip source-route
ip cef
ip name-server 62.28.40.173
ip name-server 62.28.116.41
vlan ifdescr detail
license udi pid CISCO2801 sn FCZ1208949Y
redundancy
interface FastEthernet0/0
ip address 83.240.176.242 255.255.255.252
no ip redirects
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.10.254 255.255.255.0
ip access-group 110 in
ip nat inside
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.20.254 255.255.255.0
ip access-group 120 in
ip nat inside
interface FastEthernet0/1.3
encapsulation dot1Q 3
ip address 192.168.30.254 255.255.255.0
ip access-group 130 in
ip nat inside
interface FastEthernet0/1.4
encapsulation dot1Q 4
ip address 192.168.40.254 255.255.255.0
ip access-group 140 in
ip nat inside
interface ATM0/3/0
no ip address
shutdown
no atm ilmi-keepalive
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 180 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 83.240.176.241
logging esm config
access-list 110 deny   ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 110 deny   ip 192.168.10.0 0.0.0.255 192.168.30.0 0.0.0.255
access-list 110 deny   ip 192.168.10.0 0.0.0.255 192.168.40.0 0.0.0.255
access-list 110 permit ip any any
access-list 120 deny   ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 120 deny   ip 192.168.20.0 0.0.0.255 192.168.30.0 0.0.0.255
access-list 120 deny   ip 192.168.20.0 0.0.0.255 192.168.40.0 0.0.0.255
access-list 120 permit ip any any
access-list 130 deny   ip 192.168.30.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 130 deny   ip 192.168.30.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 130 deny   ip 192.168.30.0 0.0.0.255 192.168.40.0 0.0.0.255
access-list 130 permit ip any any
access-list 140 deny   ip 192.168.40.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 140 deny   ip 192.168.40.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 140 deny   ip 192.168.40.0 0.0.0.255 192.168.30.0 0.0.0.255
access-list 140 permit ip any any
access-list 180 permit ip 192.168.10.0 0.0.0.255 any
access-list 180 permit ip 192.168.20.0 0.0.0.255 any
access-list 180 permit ip 192.168.30.0 0.0.0.255 any
access-list 180 permit ip 192.168.40.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router#
Jon Marshall
Ricardo
Can you post config of the switch indicating which port is connected to the router. Can you also post the output of "sh vlan brief" from your switch.
Obviously each vlan should only be able to ping their own gateway on the router because of your acls.
Jon
