Configure a IP-SLA on ISR 4K
Xiao Guai
Hello
Is it possible to configure IP-SLA on SR4K which runs IP BASE license?
Referring to the URL below, It says IP-SLA is included on ISR4k from "Table 3. Cisco IOS XE Software Embedded Management Features".
But it also says Application Experience (AX) features can support IP-SLA from "Table 5. Cisco ISR 4000 Feature Bundles".
Does that mean I cannot configure IP-SLA on ISR4K without applying for AX license?
Or is it possible to configure IP-SLA with only IP BASE license?
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html
Thanks.
As @Georg Pauwen mention SEC license is sufficient for IP SLA
It think you missing that the datasheet talking about IP SLA hybrid cloud not normally IP SLA' IP SLA hybrid need AX.
https://www.thousandeyes.com/blog/network-performance-monitoring-cisco-hybrid-wan
MHM
you don't need the AX license, the SEC (security) license is sufficient.
--> Security (SEC) or Security with No Payload Encryption (SEC-NPE): This license includes features for securing network infrastructure.
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html#ISR4000InterfacesandModulesSupport
MHM
