"IP routing" command on Cisco IE-3400H-16T not working.
mapletking
I have a Cisco IE-3400H and I am trying to enable "ip routing". When I type in the command, I get ... % Incomplete command.
P1F1V1-ERM6(config)#ip routing
Am I missing something? Thnx
2 Accepted Solutions
Ok. I'm 99.8% sure that ip routing is enabled on the switch.
You can go ahead and configure a
routing protocol.
Regards, LG
*** Please Rate All Helpful Responses ***
Thanks @mapletking for that output.
Go ahead yes !
Best regards
6 Replies 6
Hello @mapletking ,
ip routing should be enabled by default in IE-3400 switches.
Can you try:
P1F1V1-ERM6(config)#ip routing ?
and share with us?
Or try to enable one of the supported routing protocols:
P1F1V1-ERM6(config)#router rip
Regards, LG
M02@rt37
Hello @mapletking
Meaning CLI wait other key word after.
Please share this output:
Note that if you have
ip route
command, it means that routing feature is available.
Best regards
mapletking
Thanks for your prompt reply!
protocol IP routing protocol
routing protocol.
Regards, LG
Go ahead yes !
Best regards
balaji.bandi
check
show run all | in routing
what IOS code running on the device ?
IOS XE - Essential License (default) only support Static Routing, If you like to use any IGP / BGP you need  (network advantage License)
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-ie3400-rugged-series/cat-ie3400-rugged-series-ds.html
BB
