Configure backup point to point link on VSS switches
Wafabewafa
I have two core switches in each office connecting both office one through point-to-point.
Now i have second point-to-point which i wan to use as backup.
see attach diagram, main point-to-point is configure in Vlan not as routed port..
What is best way to achieve it?
If both links are routed links then your config will work as its floating static so the AD of 20 will be more preferred as its lower  , i would use tracking and ip sla to enforce it as well so it is removed from the table straight away and replaced with the backup route
Mark Malone
If your certain you want no traffic to pass the backup link while primary is up and its all layer 2 links you can use STP cost and increase the cost of its link becoming less preferred than the primary , if its layer 3 depends on the protocol and the metrics available that you can use
Here is config for 100MB link.. second link would be standby10MB..
Switch 1
interface GigabitEthernet2/5/3
 description 100MB point-to-point
 switchport
 switchport access vlan 55
 switchport mode access
interface Vlan55
 description New Point To Point
 ip address 10.57.10.1 255.255.255.0
 ip flow ingress
Switch 2
switchport
interface Vlan55
ip address 10.57.10.2 255.255.255.0
ip flow ingress
I was thinking to  route the traffic as
100MB link ip route x.x.x.x x.x.x.x 10.57.10.1  20
10 MB link ip route x.x.x.x x.x.x.x 10.57.11.1 30
