Configure BGP on 7204 Router with EIGRP
dacruzer1
I need to configure BGP on our 7204 and 2811 router.  The 7204 is our main router and currently running EIGRP internally.  Our remote locations just moved to an MPLS connectivity and they have a 2811 router.  I will need to configure BGP for the routing protocol. I have the AS number and the remote AS number. Attached is the the current configuration of the two routers.
Your help is greatky appreciated.
Alfred
Please remember to rate the thread when issue gets resolved.
Edison Ortiz
On the 7200
router bgp [your AS]
bgp router-id 10.10.128.206
no synchronization
neighbor 10.10.128.205 remote-as [their AS]
network 0.0.0.0
redistribute eigrp 100
redistribute connected
no auto-summary
router eigrp 100
redistribute bgp [your AS] metric x x x x x
On the 2800
bgp router-id 10.10.29.194
no synchronization
neighbor 10.10.29.193 remote-as [their-AS]
network 10.10.67.0 mask 255.255.255.0
no auto-summary
Hi Edison,
Thanks much for the help.  I will be configuring this tonight after hours and I will keep you posted.
Alfred
will do!
