Configure Cisco Switch - Security-Urgent Help
rania20052006
Dear All,
I am still new to the world of Cisco.
I have here in My Network one Core Switch 4506 with 15 Edge Switch 3560.
We configure the Core Switch with This Command :-
A- )
HO-CSW-01(config)#username design privilege 15 password kabdesign
B- )
HO-CSW-01(config)#username support privilege 5 password support
C- )
HO-CSW-01(config-line)#login local
as you can see from the commands, i do not have CISCO Secure TACKCAS.
My manager asked me to find a way to create user name & Password for each one of my user so & to be able to Print a report who login & what time he enter.
I am searching for any Product - for example microsoft if i can enable RADUIS -
Can any one Please guide me if there is a way to configure the Core Switch with login to to the IP-Address of the RADUIS or any thing, please any one update me , will highly appritiated .
peterledwidge
Have a look at the following link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fsecur_c/fsaaa/scfathen.htm#1001192
Depending on how many people you need to track
you could possibly set up aaa locally
aaa new-model
aaa authentication login default local
username a password b
username x password y
He can certainly do the authentication local part of it. But as I read the original post I believe part of what his manager wants is reporting of who has logged in and what time. For that I believe he needs aaa accounting and some kind of external server to do the aaa accounting record processing.
Rick
Rick
Yes, this is what i need.
i am confused, what is the best software , i can work on it in order to do that , like microsoft.
and how the command wrote in the core switch to tell him that go to this server to authenticate the users.
please help
