Configure DHCP on ASR Router for QinQ Subinterfaces
claurie
Hi All,
Currently trying to test DHCP on QinQ Sub-Interfaces on an ASR 1001-X. Static Addressing works without a hitch, but when setting the sub-interface with the DHCP Pool Default-Router address to enable a remote router to obtain an IP Address via DHCP, the 'dhcp server' receives the DHCPDISCOVER message but nothing appear to be sent to the remote router. I have included DHCP Pool, sub-interface configurations below along with 'sh ip dhcp server statistics' output and
 . I would appreciate any and all advice on what I am missing!
no ip domain lookup
ip dhcp excluded-address 103.xxx.xxx.233
ip dhcp pool RC_Trial
network 103.xxx.xxx.232 255.255.255.248
dns-server 8.8.8.8 8.8.4.4
default-router 103.xxx.xxx.233
domain-name xxxxx.com.au
lease 8
INTERFACE
interface GigabitEthernet0/0/3.30x
description xxxxxxx
encapsulation dot1Q 30xx second-dot1q 35xx
ip address 103.xxx.xxx.233 255.255.255.252
ip access-group ACL-DHCP-Allow out
ip access-list extended ACL-DHCP-Allow
permit udp any host 255.255.255.255 eq bootps bootpc
permit ip any any
'SH IP DHCP SERVER STATISTICS' Output
Memory usage 20550
Address pools 2
Database agents 0
Automatic bindings 0
Manual bindings 0
Expired bindings 0
Malformed messages 2533
Secure arp entries 0
Renew messages 0
Workspace timeouts 0
Static routes 0
Relay bindings 0
Relay bindings active 0
Relay bindings terminated 0
Relay bindings selecting 0
Message Received
BOOTREQUEST 0
DHCPDISCOVER 2512
DHCPREQUEST 20
DHCPDECLINE 0
DHCPRELEASE 0
DHCPINFORM 0
DHCPVENDOR 0
BOOTREPLY 0
DHCPOFFER 0
DHCPACK 0
DHCPNAK 0
Message Sent
BOOTREPLY 0
DHCPOFFER 0
DHCPACK 0
DHCPNAK 0
Message Forwarded
BOOTREQUEST 0
DHCPDISCOVER 0
DHCPREQUEST 0
DHCPDECLINE 0
DHCPRELEASE 0
DHCPINFORM 0
DHCPVENDOR 0
BOOTREPLY 0
DHCPOFFER 0
DHCPACK 0
DHCPNAK 0
DHCP-DPM Statistics
Offer notifications sent 0
Offer callbacks received 0
Classname requests sent 0
Classname callbacks received 0
Edge.TR.M1#sh ip sockets
Proto Remote Port Local Port In Out Stat TTY Output IF
17 103.xxx.xxx.134 50149 103.xxx.xxx.130 161 0 0 2001001 0
17 --listen-- 110.xxx.xxx.50 162 0 0 2001011 0
17 --listen-- 110.xxx.xxx.50 53998 0 0 2001011 0
17(v6) --listen-- --any-- 161 0 0 2020001 0
17(v6) --listen-- --any-- 162 0 0 2020011 0
17(v6) --listen-- --any-- 49477 0 0 2020001 0
17 103.xxx.xxx.134 514 103.xxx.xxx.65 51381 0 0 400210 0
17 0.0.0.0 0 --any-- 67 0 0 2002211 0
Craig
Thanks for the update. Glad to know that it is now working for you. My guess is that specifying the option 82 information was more significant but it is certainly possible that Paul's suggestion for trust all was also helpful. The important thing is that now it is working for you.
Rick
15 Replies 15
Hello
With the encapsulation on the subinterface it is now being tagged -
so if the device that connects to the physical interface of your rtr is a switch then that port needs to be a trunk and be able to accept vlan 30 or if it’s a rtr it needs to be in the same sub interface
Kind Regards
Paul
Hi Paul,
Thanks for the reply. The remote end is a router. Connection between the two routers is a Layer 2 ethernet network that implements the Qin Q tagging that is handed of the ASR. There is no possibility of the remote router being a member of any VLAN.
Cheers
Craig
Craig
I do not understand your statement "There is no possibility of the remote router being a member of any VLAN." Paul makes a good point that your subinterface will be sending Ethernet frames tagged with vlan ID. So the remote router needs to process tagged Ethernet frames. If the router is not a member of any vlan will it process tagged frames?
Perhaps you can give us some information about the remote router and how it is configured?
Rick
Hi Richard,
Thanks for the reply. I can see the confusion. The Ethernet Broadband network connecting the two routers removes the tags 'at the edge' before delivery to the remote router. The remote router is using IPoE on its WAN Port if that makes any clearer.
Craig
Thanks for the clarification. My experience with QinQ has not been that tags were removed before delivery to the remote router. But if that is happening in your network then we need to look for some other issues.
To make sure that I am understanding correctly - if you keep the sub interface QinQ configuration and manually configure IP addresses on both sides then there is successful communication? That would certainly indicate that the issue is about DHCP. Perhaps debug for DHCP might shed some light on the issue.
Rick
Hi Richard,
Static IP assignment using same subnet works without issue. I will debug dhcp server asap.
Craig
Hi Richard,
Debug ip dhcp server packet output:
*Apr 20 00:13:27.865: DHCPD: Reload workspace interface GigabitEthernet0/0/3.31101 tableid 0.
*Apr 20 00:13:27.866: DHCPD: tableid for 103.102.223.237 on GigabitEthernet0/0/3.31101 is 0
*Apr 20 00:13:27.866: DHCPD: client's VPN is .
*Apr 20 00:13:27.866: DHCPD: No option 125
*Apr 20 00:13:27.866: DHCPD: inconsistent relay information.
*Apr 20 00:13:27.866: DHCPD: relay information option exists, but giaddr is zero.
Does this give you any direction to look?
Craig
Thanks for the debug output. There are messages that I am not clear about but that certainly do show that there is some problem with the configuration. One of those messages is
I am not sure about it but I wonder if it relates to the fact that your DHCP pool describes a network with mask 255.255.255.248 but the mask of the interface is different
I am also not clear about this message
giaddr is the gateway address in the DHCP request and is typically used when the DHCP request is being sent to a server whose IP address is in a subnet different from the subnet where the client is. If the remote router and your router are in the same subnet then I am not sure why the relay information option is used but the DHCP request has giaddr as zero. That would seem to reflect some issue on the remote router request.
I suggest changing the interface mask in the configuration to be consistent with the mask in the DHCP pool. If that does not resolve the issue then I believe that we need to find some information about the configuration of the remote router.
Rick
Hello
@claurie wrote:
Hi Richard,
Try enabling dhcp to trust packets with a zero gateway-address
ip dhcp relay information trust-all
Kind Regards
Paul
Hi Paul and Richard,
Thanks for pointing me in the right direction. Implemented Paul's ip dhcp relay information trust-all
Also, I found out that Option 82 was employed for the DHCP packets we were receiving.
Implemented the following without specifying relay agent information in the ip DHCP class to allow use of any Option 82 information (not sure at present which of these two actions, or both, worked - but work it did:
ip dhcp pool Test
network 103.xxx.xxx.236 255.255.255.252
default-router 103.xxx.xxx.237
domain-name xxxxxxx.com.au
lease 8
class Option82
ip dhcp class Option82
Craig
Rick
Sorry does anyone know how to find a cisco document for  configuring the BNG/BRAS with IPOE in ASR1002 - IOS XE??
thanks in advance
claurie
Thank You Both
