RV34x WAN DHCP Client Option 121
swamplynx
rvLooking to stand up a new site with a RV345P router already in inventory, however the ISP (Starlink) requires the WAN DHCP client to support option 121 to pull an additional Classless Static Route for debug / management purposes, e.g...
Option: (121) Classless Static Route
Length: 23
192.168.100.1/32-0.0.0.0  (the route to the management interface of the dish)
34.120.255.244/32-0.0.0.0
default-100.127.255.7
Option: (255) End
Does the WAN DCHP client on RV34x support option 121 to build the routing table?
Mark Elsen
                      >Does the WAN DCHP client on RV34x support option 121 to build the routing table
 Presumably not , can't see any references to it in this document :
          https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5708-configure-the-lan-and-dhcp-settings-on-the-rv34x-series-rout.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
