Configure EPL circuit connection
Pdobbinsit
Community Member
We recently got an EPL circuit through Time Warner and would like some help with configuring the connection from their Adva device to our network.  Can anyone point me in the right direction?
Thanks.
9 Replies 9
Philip D'Ath
Meraki Community All-Star
What type of Cisco device are you plugging it into?  A Cisco router (if so which), an ASA?
Yes, ASA at both ends.  Assuming that's the best choice rather than the 2960 switches.
Philip D'Ath
I am in a different country to you and have no idea what this type of circuit is.  I have read their web site and it says it is a layer 2 private Ethernet circuit.
I assume the two sites you currently have use different IP addressing?  If they use the same IP addressing then you could just plug them directly together using the 2960's.
Do the two sites share the same security profiles?  Aka, are they both the same company with the same management and IT team?  If not, connect them via the ASA's.
Some models of 2960 support "basic" layer 3, which would be perfect if the two sites have the same security profiles and use different subnets.  Which exact models of 2960 are you using (you can get this from "show inventory")?
Same company and all, different subnets. 2960X-48TS-L
Philip D'Ath
Well this is going to work out great.
Lets create a new VLAN10 on each switch, place a port in it, and plug the EPL circuit into it.
Something like:
site 1:
vlan 10
  name WAN
  exit
ip routing
interface vlan10
  ip address 192.168.10.1 255.255.255.252
  exit
interface Gigabit a/b/c
  switchport mode access
  switchport access vlan 10
  exit
ip route 0.0.0.0 0.0.0.0 <asa IP address>
ip route <remote subnet> 255.255.255.0 192.168.10.2
site 2:
vlan 10
  name WAN
  exit
ip routing
interface vlan10
  ip address 192.168.10.2 255.255.255.252
  exit
  exit
ip route <remote subnet> 255.255.255.0 192.168.10.1
On each site, make the default gateway for all machines the IP address of the local switch (probably on your VLAN1).
Thank you. I'll try this and let you know how I make out.
Correct on the circuit.
Philip D'Ath
Also, what are the subnet(s) used at both of the sites?
