Configure Regular Expression on Cisco ACE
cannone78
Hi all,
I need to configure a load balance based on url filtering:
All the traffic sent to https://home/can should be load balanced on a group of server (eg. x1, x2, x3); while all the traffic sent to https://home/can/<any-sub-directory> should be load balanced on other server (ex. X4 X5).
My question is: how can I configure correct url regular expression to correctly filter  the two above url?
I'm thinking something like this but I'm not sure if I on the right way:
Many thanks in advance for your support
Gianluca
Marwan ALshawi
You can create two Class maps type https and specify something like the bellow
(config)# class-map type https inspect HTTP_INSPECT
(config-cmap-http-insp)# match header Host header-value
.*home/can
For the second one make it like
.*home/can.*
Many thanks for your answer very clear.
Only the last doubt: since the directory 'can' of my path could change, If I need to make two generic filter without specify the exact name:
  1. https://home/ --> to server x1,x2,x3
  2. https://home//sub-directory   ---> to server x4,x5
For the 1st filter, can I configure somethink to filter a generic directory excluding subdirectory?
Something like https://home/*/
Many thanks for you support.
Gianluca
