Configure Routing not working in SG550XG-24F
mpandolfo1980
Hello dears,
I have a Cisco SG550XG-24F configured with 3 Vlans.
I need to configure Routing between these Vlans but I cannot.
Can you help me with some information?.
I have configured one network interface for each Vlan and Static routes but I dont know why doesn´t work?.
Please help!.
Thanks.
Hi @mpandolfo1980 ,
Check if your device has the sentence in the route shown in the image:
I hope it's useful for you
5 Replies 5
balaji.bandi
The switch out of the box will be operating in layer 2 mode. This won't work for what we need it to do. Navigate to Administration > System Settings and click the radio button for L3 and then click apply. Your switch will reboot and all of the settings will be cleared. When it comes back up, it will be operating as a layer 3 switch.
BB
Thanks very much for your help and response.
I don´t find the button for layer 3 (I send an image).
Maybe this model doesn´t have this button?.
Thanks a lot.
Miguel.
Hi @mpandolfo1980 ,
Hi Luis, thanks for you response.
I have configured 3 VLANs, each one with an interface.
I have one port in VLAN 30 and one in VLAN 40 both configured like ACCESS.
One device conected in Port VLAN30 can reach ping to interface VLAN 10.10.30.1 and it is the same with another device conected in port Access VLAN30 can Ping to interface VLAN 30.
But I can not reach ping between diferents VLAN, for example the notebook in VLAN 40 with IP 10.10.40.30 cannot reach ping to interface VLAN 30 IP 10.10.30.1.
Maybe i need configure static routes or configure port like layer 3 but nothing work fine.
Thanks a lot for your help.
MiguelPing VLAN30 OK.PNGPing VLAN40 OK.PNGIP Interfaces.PNGForwarding table.PNGPort layer.PNGStatic Routes.PNG
