Configure SSH on 3845 router
saimbt
I have configured SSH on my router.
following are the relevant commands used.
username test password xxx
aaa new-model
aaa authentication login default local
aaa session-id common
ip ssh rsa keypair-name <string>
line vty 0 4
exec-timeout 1 30
password 7 <password>
transport input telnet ssh
When I telnet the router on port 22, I get the following message
Connected to
Escape character is '^]'.
SSH-1.99-Cisco-1.25
Connection closed by foreign host.
Please let me know what could the problem be.
sh ip ssh
SSH Enabled - version 1.99
Authentication timeout: 120 secs; Authentication retries: 3
sh ssh
%No SSHv2 server connections running.
%No SSHv1 server connections running.
Am I missing something....
-Sai.
15 Replies 15
Richard Burts
I see in the connection message:
SSH-1.99-Cisco-1.25
I had problems in using SSH with that version level. When I upgraded the IOS to a version that supported SSHv2 my problem was resolved.
Rick
Rick
Updated to ssh ver 2
still the same error Escape character is '^]'.
SSH-2.0-Cisco-1.25
I am using c3845-advipservicesk9-mz.123-11.T5.bin
-Sai.
Harold Ritter
You seem to be missing some fundamental steps, such as configuring the "ip domain-name".
Please refer to the following URL for the configuration steps to configure SSH:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120limit/120s/120s5/sshv1.htm#wp18428
Hope this helps,
Please discard my last message as "ip domain-name" is now required before proceeding with the rest of the ssh config.
Harold Ritter
Can you try using a SSH client software instead of doing a telnet to port 22.
Hope this helps,
Harold Ritter
Hope this helps,
Tried using the client but nuthing happens, enabled debug ip ssh and here is the output upon doing a telnet on port 22
*Jun 28 18:36:21.557 IST: SSH1: starting SSH control process
*Jun 28 18:36:21.557 IST: SSH1: sent protocol version id SSH-1.5-Cisco-1.25
*Jun 28 18:36:57.537 IST: SSH1: protocol version id is -
*Jun 28 18:36:57.637 IST: SSH1: Session disconnected - error 0x1B
-Sai
Can you enable the "debug ip ssh" and try connecting using the SSH client.
I think you did not understand my post of June 23 where I suggested that the problem might be the SSH implementation and suggested an upgrade to SSHv2. You replied that you had upgraded and still have the issue.
But the output in this message clearly shows that the router is not running SSHv2 but is running SSHv1:
I do not know what you upgraded, but I strongly suggest that you upgrade the router to run SSHv2.
I also agree with Harold that you should test with an SSH client and not by trying to telnet to port 22.
Rick
Rick
Hi Rick,
I tried with both SSHv1 and SSHv2 and get the same error message. Moreover when I try to communicate with the router through Putty (SSH client), i do not get any response from the router and also "debug ip ssh" does not bring any output., whereas pure telnet works absolutely fine.
in vty 0 4
transport input is set to telnet and ssh
transport output is set to all
transport preferred is set to ssh
-Sai
I would feel better if you showed me router output where it shows SSHv2 and not working.
I am very interested in your comment that when you attempt to access with Putty that you get no response. It makes me think that the SSH from Putty is not getting to the router for some reason. At first I thought that it sounded like an access list somewhere along the path was not permitting the access. But then I think that if it were an access list issue it should also stop the telnet to port 22. So if I believe that it is not an access list question then I wonder if it is something in the Putty setup. Can you verify the Putty setup? Is that end station with Putty the same one that you use for telnet to port 22? Is the end station with Putty able to access other routers with SSHv2?
Rick
Rick
Hi Rick,
i tried to SSH using a machine that is not in LAN and it worked... I guess its something to do with the Firewall settings, it might be blocking SSH somewhere..
let me catch hold of the firewall guys, guys I am comingggggggggggggggggg :)
-Sai.
I am glad that we are making progress in getting this solved.
Good luck in dealing with the firewall guys.
Rick
Rick
Hi rick,
the firewall was set only to send out telnet connections only
its working from LAN as well....
thanks a lot..
-Sai.
