2811 - Need specific IOS!
astroman
Hello all -->
I have a 2811 router, running 12.3(8)T6 (SPSERVICES). I would like to configure this router as a VPN endpoint, firewall, but I'll also need to run voice through this device as well, in the future. When I load 12.4.1a (ADVANCED SECURITY), the IOS does not recognize the 2 FXO interfaces I have installed.
I need an IOS for this device that will ultimately run firewalling, VPN, Voice and IPS. Is this possible, or can I only have one or the other?
I will cross-post to other boards...thanks in advance!
tekha
Level 3
Level 3
Well obviously you would get everything working in "Advanced Enterprise Services", but I think you could settle with "Advanced IP Services".
See this PDF file. First page, lower right corner.
http://www.cisco.com/warp/public/765/tools/quickreference/isr.pdf
tekha
Level 3
Level 3
Thank you very much, I've just dl'ed Adv. IP Services.
