Configuring 2 or more subnets on the same Frame Relay T1
asidney
my question is on how to configure 2 or more subnets on a single Frame Relay T1 interface using the same DLCI (dlci 851 in this case)?
In other words, I need to configure two subnets: 10.5.15.1/240 and 10.5.15.17/240 on a T1 that terminates at my Cat 6509. I have a single dlci (dlci 851) that I need to map or associate these subnets to locally.
8 Replies 8
Edison Ortiz
You create subinterfaces.
interface s0/0
encapsulation frame-relay
frame-relay lmi-type [ansi | cisco]
interface s0/0.1
ip address 10.5.15.1 255.255.255.240
frame-relay interface-dlci [remote dlci]
interface s0/0.17
ip address 10.5.15.17 255.255.255.240
Please rate helpful posts.
Edison
In the original post Anthony was very clear that he had a single DLCI. Your suggested solution of configuring subinterfaces requires 2 DLCIs.
I am not clear why Anthony needs two subnets on a single DLCI which is inherently a point to point connection. But if he does need two subnets then I believe that the appropriate solution is to configure secondary address on the frame relay interface. It could be done on the primary physical interface or could be done on a subinterface. Without knowing more about the environment and the requirements I would probably suggest configuring a single subinterface with secondary addressing. The configuration would look something like this:
interface s0/0.851
ip address 10.5.15.17 255.255.255.240 secondary
frame-relay interface-dlci 851
Rick
Rick
Rick, you are right. My apologies for posting an incorrect suggestion.
Edison
Your instincts were right. Your solution is a common and very good solution - just for a slightly different question.
Rick
Rick
I'd add one more thing - the sub-interface has to be point-to-point, so any traffic matching subnet but not matching local interface address will be send out. If the sub-interface is point-to-multipoint, or if this configured on main interface then static mapping for remote secondary address will be necessary since InARP apparently works only on primary address.
asidney
Thanks for the reponse. However, configuring subinterfaces was not the issue. I've done that many times before. What was unique this time is that I needed to apply the same dlci to both subintfs. IOS complains when you try to do this because it knows the dlci is already configured on the first subintf. What I realized I had to do was apply the dlci to the primary interface only. This seemed to have worked.
interface Serial1/1/3:0
no ip address
shutdown
no fair-queue
frame-relay lmi-type ansi!
interface Serial1/1/3:0.2 point-to-point
bandwidth 1544
ip address 10.5.15.1 255.255.255.240!
interface Serial1/1/3:0.3 point-to-point
bandwidth 1544
I think you don't need to use subinterface.
like this:
interface s0/0
This makes sense and is much easier.
Thanks for the info! I'll try it.
