Configuring 7206 for vlan-tagging
jasonmathew1
hey guys,
need some assistance if possible..
using an MPLS Ethernet handoff provided by the ISP.
RouterA is a Juniper M10i with the following config
RouterA>
show configuration interfaces fe-0/2/0
vlan-tagging;
unit 1 {
description "(new turnup)";
vlan-id 254;
family inet {
address 10.147.15.5/30;
I have a 7206 as RouterB at the other end of the MPLS link connected to FastEthernet 1/0...what configuration do I need on the 7206?
network.king
Level 4
Level 4
Hi ,
Try configuring this .
int fa1/0.254
description
encapsulation dot1q 254
ip address 10.147.15.6 255.255.255.252
Hope this helps
regards
vanesh k
network.king
Level 4
Level 4
Hi ,
int fa1/0.254
description
Hope this helps
regards
vanesh k
One more command :
int fa 1/0
no shut
Hope this helps.
Hey guys,
thanks for your inputs!
