12-28-2006 09:16 PM - edited 03-03-2019 03:12 PM
Every now and then, links to my remote offices are lost due to T1
failures. The symptoms of the malfunction line involve extended pings
showing dropped packets. Other times, no traffic will pass through the
link at all; the T1 module interface status will either be UpDown or
DownDown. The topology is straight-forward, containing only
point-to-point IP addressing between the Cisco routers, which include
various combinations of the following models: 7206, 3640, 2621, 1721.
I have found that physically unplugging the T1 cable from the interface
module and reinserting it will bring the connection back to normal.
Reseating the telecom company's Pairgain card or simply reloading the
router will also work. Telecom has only ever seen clean circuits after
the problem is resolved.
Part of my troubleshooting has been to replace every piece of
hardware, including swapping WIC modules, routers, and Pairgain cards.
I need a technical explanation for what is occurring. Is this an issue
I should bring to my telecommunications provider? Or is this an issue
with the Cisco hardware?
12-28-2006 09:39 PM
What version of IOS, and what flavor of T1 interface (WICT1 v1, v2, Flex, serial port ...)
What is the model number of the router at your local end?
Please post a sanitized "show run" and "show version"
Also try to get a "show service-module"
Details help a lot.
Good Luck
Scott
01-01-2007 10:53 PM
The WIC T1 DSU modules are Version 1.
I've pasted "show version" and "show service-module" for both a local router and a remote router, respectively. There should be nothing of note in the interface running-configuration: private point-to-point IPs, fair-queue, and bandwidth.
Thanks in advance for any assistance!
Brian
LOCAL_2621>sh ver
Cisco IOS Software, C2600 Software (C2600-ADVIPSERVICESK9-M), Version 12.4(8a), RELEASE SOFTWARE (fc2)
LOCAL_2621 uptime is 14 weeks, 4 days, 4 hours, 37 minutes
Cisco 2621XM (MPC860P) processor (revision 3.1) with 127308K/3764K bytes of memory.
Processor board ID FOC08251CWQ
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
2 Serial interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
LOCAL_2621#show service-module
Module type is T1/fractional
Hardware revision is 0.88, Software revision is 20050811-0.3,
Image checksum is 0x80ACD1B3, Protocol revision is 0.1
Receiver has no alarms.
Framing is ESF, Line Code is B8ZS, Current clock source is line,
Fraction has 24 timeslots (64 Kbits/sec each), Net bandwidth is 1536 Kbits/sec.
Last module self-test (done at startup): Passed
Last clearing of alarm counters 1w1d
loss of signal : 1, last occurred 1w1d
loss of frame : 2, last occurred 19:46:22
AIS alarm : 1, last occurred 19:46:22
Remote alarm : 1, last occurred 1w1d
Module access errors : 0,
Total Data (last 96 15 minute intervals):
0 Line Code Violations, 2036 Path Code Violations
0 Slip Secs, 50 Fr Loss Secs, 0 Line Err Secs, 681 Degraded Mins
1336 Errored Secs, 67 Bursty Err Secs, 0 Severely Err Secs, 50 Unavail Secs
Data in current interval (480 seconds elapsed):
0 Line Code Violations, 13 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 7 Degraded Mins
13 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Remote_1721#sh ver
Cisco IOS Software, C1700 Software (C1700-SY7-M), Version 12.3(14)T1, RELEASE SOFTWARE (fc1)
Remote_1721 uptime is 12 weeks, 6 days, 4 hours, 28 minutes
Cisco 1721 (MPC860P) processor (revision 0x100) with 59872K/5664K bytes of memory.
Processor board ID FOC07230R3B (2041504212), with hardware revision 0000
MPC860P processor: part number 5, mask 2
1 FastEthernet interface
1 Serial interface
WIC T1-DSU
32K bytes of NVRAM.
16384K bytes of processor board System flash (Read/Write)
Remote_1721#sh service-module
Hardware revision is 0.96, Software revision is 20040131-0.3,
Image checksum is 0x873E3B7E, Protocol revision is 0.1
Last clearing of alarm counters 1w4d
loss of signal : 2, last occurred 19:48:18
loss of frame : 5, last occurred 19:48:18
AIS alarm : 3, last occurred 1w1d
Remote alarm : 0,
112 Line Code Violations, 619 Path Code Violations
1 Slip Secs, 48 Fr Loss Secs, 3 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 48 Unavail Secs
Data in current interval (513 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
