01-02-2020 12:14 PM
Team, I would like to use gi0/2 as a way to get my internet in from my ISP. The ONT has an Ethernet port on it, that is currently connected to an HWIC-1FE card which provides me with 100 mbps. Since I'm going to upgrade to 500 mbps, and possibly Gigabit, I need to have a compatible port on this router. Can anyone provide me with some configuration steps on how to do it?
Here's the running config on my router at the moment. Thanks in advance!
Building configuration... Current configuration : 2671 bytes ! ! Last configuration change at 10:43:44 EST Thu Jan 2 2020 ! version 15.7 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname HomeRouter-001 ! boot-start-marker boot system flash:c3900-universalk9-mz.SPA.157-3.M5.bin boot-end-marker ! ! enable secret 5 $1$d.au$f/puBghk0fn9ztVqTehNn. ! no aaa new-model clock timezone EST -5 0 ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ip dhcp excluded-address 192.168.1.1 192.168.1.30 ! ip dhcp pool internal network 192.168.1.0 255.255.255.0 default-router 192.168.1.1 dns-server 8.8.8.8 8.8.4.4 netbios-name-server 192.168.1.1 lease infinite ! ip dhcp pool internal2 network 192.168.2.0 255.255.255.0 default-router 192.168.2.1 dns-server 8.8.8.8 8.8.4.4 netbios-name-server 192.168.2.1 lease infinite ! ! ! ip name-server 8.8.8.8 ip name-server 8.8.4.4 ip cef no ipv6 cef ! ! multilink bundle-name authenticated ! ! ! ! ! ! voice-card 0 ! ! ! ! ! ! ! ! vxml logging-tag license udi pid C3900-SPE150/K9 sn FOC15505HWS license accept end user agreement license boot module c3900 technology-package datak9 ! ! ! redundancy ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! interface Embedded-Service-Engine0/0 no ip address shutdown ! interface GigabitEthernet0/0 ip address 192.168.1.1 255.255.255.0 ip nat inside ip virtual-reassembly in duplex auto speed auto ! interface GigabitEthernet0/1 ip address 192.168.2.1 255.255.255.0 ip nat inside ip virtual-reassembly in duplex auto speed auto ! interface GigabitEthernet0/2 ip address dhcp ip access-group ISP in ip nat outside ip virtual-reassembly in duplex auto speed auto ! interface FastEthernet0/0/0 description INTERNET ip address dhcp ip access-group MY-WAN in ip nat outside ip virtual-reassembly in duplex auto speed auto ! ! ip forward-protocol nd ! no ip http server no ip http secure-server ! ip dns server ip nat inside source list 1 interface FastEthernet0/0/0 overload ! ipv6 ioam timestamp ! nls resp-timeout 1 cpd cr-id 1 ! access-list 1 permit 192.168.1.0 0.0.0.255 access-list 1 permit 192.168.2.0 0.0.0.255 ! control-plane ! ! ! ! ! ! mgcp behavior rsip-range tgcp-only mgcp behavior comedia-role none mgcp behavior comedia-check-media-src disable mgcp behavior comedia-sdp-force disable ! mgcp profile default ! ! ! ! ! ! ! gatekeeper shutdown
Solved! Go to Solution.
01-06-2020 02:13 PM
Sure this was expected, can you post current config and old config to review?
01-06-2020 02:25 PM
Actually it worked, I just had to do the commands 1 by 1 and not copy and paste them all at once. Thank you both so much for all your help.
