Configuring a used 1811
markworsnop
I still havent found the right PDF manuals for the 1811 so forgive some stupid questions...
I got a 1811 from EBay, had to reset it back to scratch for my configuration.
I thought I would configured on of the 8 LAN ports with a static that I then can use as the default gateway from the network. However after configuring it, or trying to, it tells me FastEthernet9 cannot have IP Addresses on L2 links. Heck I havent a clue what this is. About the only command I have done so far is put in the passwords and try to get an IP connection.
Can anyone give me a clue how to make one of the LAN ports work so I can access the router from IP?
thank you!
10 Replies 10
Edison Ortiz
As the message implies, those ports are Layer2 capable and any Layer3 information must be applied to a virtual interface.
By default, all ports are associated to Vlan 1, so if you want to access the switch for management via IP, just enter an IP that belongs to your LAN subnet under Vlan 1.
You can create multiple Vlans and associate those Vlans to different interfaces.
For instance:
#vlan database
http://www.cisco.com/en/US/docs/ios/lanswitch/command/reference/lsw_u1.html#wp1012545
(vlan)#vlan 2
(vlan)#vlan 3
(vlan)#vlan 4
(vlan)#exit
#config t
(config)#int f1
(config)#switchport access vlan 2
(config)#interface vlan 2
(config)#ip address 192.168.2.1 255.255.255.0
and do the same for the other ports and associate them with different Vlans.
HTH,
__
Edison.
At this point I only need one of the ports, so that is pretty easy. Thank you!
The final for this is to have two internet connections and the LAN will connect to the ASA 5505. I guess I will setup one of the LAN for maintenance access and another one to go to the ASA. Does that sound about right?
THANK YOU AGAIN!
If you are going to use the LAN connection from this router to the ASA, you can use the regular Layer3 ports on this router and do not use the L2 etherswitch modules. The etherswitch module allows you to connect users in small office environment without the need of purchasing an additional switch for LAN.
__
Edison.
Please rate helpful posts
Is this something I need to configure in the OS or did I get the wrong router?
If you post the show run output I can point you to the L3 and L2 interfaces from this router.
Current configuration : 1288 bytes
version 12.4
hostname msirouter1
boot-start-marker
boot-end-marker
enable secret 5 $1$8GPy$O3zKnrRrjgPnwysgGPGAh0
enable password xxxx
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
interface FastEthernet0
no ip address
shutdown
speed auto
full-duplex
interface FastEthernet1
no ip address
shutdown
speed auto
full-duplex
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
interface Vlan2
ip address 10.215.81.2 255.255.255.0
interface Async1
no ip address
encapsulation slip
router rip
redistribute connected
network 10.0.0.0
ip classless
ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
snmp-server community public RO
control-plane
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
password xxxxxx
login
end
Based on the router datasheet:
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/ps6184/product_data_sheet0900aecd8028a95f_ps5853_Products_Data_Sheet.html
It has (2) FE WAN Ports so I'll assume the first 2 FE interfaces are Layer3 and you should be able to enter an IP address under those interfaces.
HTH,
__
Edison.
Those are the two ports for the WAN.
The connotation of WAN ports can be a little misleading. Those ports can be used for Layer3 LAN connection. The only special quality they have over the remaining FE ports is the ability to accept a Layer3 address under their interfaces.
If you want to use the L2 FE ports with the virtual interface, that can also be doable.
__
Edison.
I need 2 ports for the internet connections. I would have thought FE0 and FE1 would be used for that. There isnt anything else left to use for the LAN connections other than FE2-9
