04-16-2005 03:27 AM - edited 03-03-2019 09:18 AM
i´m trying to configure the abovementioned router with an adsl access. we have a fixed ip add from our isp operator with a mask of /32. the router does not allow this mask and our operator cannot/will not change the mask unless we ask for another mask which entails more cost.
can anyone help me with this?
regards
fernando
04-16-2005 04:09 AM
Hi Fernando
can you send the configuration file.
Binoy
04-16-2005 04:38 AM
interface FastEthernet0/0
description LAN DefaultGateway
ip address 1.x.x.x.255.255.0
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0/0.1 point-to-point
pvc 0/35
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
load-interval 30
dialer pool 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname %%%%%
ppp chap password &&&&&
ppp pap sent-username %%%% password &&&&&
ip classless
ip route 0.x.x.x.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 1.x.x.x.0.0.255
dialer-list 1 protocol ip permit
i´v done some troubleshooting using;
debug atm events
debug atm packets and
sh dsl int atm
all results that i got were the required ones.
it seems like the router is definately training with the dslam on the other side.
thanks
04-16-2005 03:31 PM
You don't want to debug atm - the sh dsl int atm will show you if the ATM layer is up. Debug PPP. In particular look at the IPCP messages. If you can't figure it out from that try posting the output of a debug ppp negotiation in this thread.
Edit: At a second glance your config appears to be missing encapsulation on your ATM sub interface.
Try using PPPOA instead of the PPPOE client. Remove your current pvc configuration and try this:
interface atm 0/0/0.1 point-to-point
pvc 0/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
04-18-2005 02:18 AM
the sh dsl int atm does show that it is up (SHOWTIME) appears. When I try the ppp debug nothing happens.
I think that a call never does initiate. I think that the problem lies with the dialer/dialer list.
I`ve looked nad tried various exmamples but to no avail.
I have installed many soho adsl products but never had any problems. This is the 1sy time I install adsl using a wic.
By the way i´m not sure if its important mentioning that I am in Europe.
thanks
04-19-2005 03:56 AM
Do you use ADSL over POTS or ADSL over ISDN? I mention this because you need the WIC-ADSL-I for ADSL over ISDN. The WIC-ADSL works over POTS only.
If your router has a build in ATM interface you should make sure that it supports the correct ASDL mode ...
Greetings from germany (we use ADSL over ISDN)
Matthias Köhler
04-19-2005 07:18 AM
hi matthias,
it´s adsl over pots. and i´m using a 2811 modular router with a wic-1adsl.
i think that the problem lies within the dialer interface configuration.
when i do debugging, the wic does train with the dslam on the operator side. BUT when i do debug ppp,
i get no result. this means that the dialer isn´t working. i think! it´s not even trying to dial out. correct.
04-19-2005 10:58 PM
Hello fcatalao,
i had a look at your config and i haven't four your decalation of interesting config or a "dialer persistant" statement.
You have the "dialer-list 1 protocol ip permit" statement but you have missed the appropiate command in your dialer profile.
Try adding a "dialer-group 1" or command to your dialer interface.
If it still doesn't work you could use the debug dialer commands.
Matthias Köhler
