Configuring an 3845
KDSM
I'm trying to configure a 3845-MB as a fall back device to the one that is currently running in production and I can't seem to get some of the configuration to work.  I started out by making a copy (to a text file) of the running config and just applying it to the back up device. That work with the following exceptions.  On voice-port 0/2/0:23 and voice-port 0/2/1:23 I can't get this config line to apply "echo-cancel coverage 64".  I have enabled echo-cancel on both ports (echo-cancel enable) but get an error when trying the other command  "Invalid input detected at '^' marker" it's pointing to the 64.  There are 4 other voice ports that have this configured.
The other configuration issue I'm having are with the following lines.
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 192.168.1.2 port 2000
max-ephones 450
max-dn 800 dual-line
default-destination 2100
voicemail 1000
call-forward busy 1000
call-forward noan 1000 timeout 24
moh music-on-hold.au
I don't get an error on the first command line but all the rest show up with invalid input detected line.
As back ground I was asked to support this device and other switches and router when the employee that normally does it moved to a different company. So any help would be greatly appreciated.
17 Replies 17
I have read that echo-cancel coverage comes enable by default on the voice-port the problem I'm having is entering the "echo-cancel coverage 64" command and have it stay in the configuration. If I use the "echo-cancel coverage ?" on that port it does show me the coverage list.
I can't swear to it, but I have a vague recollection of 32ms being the maximum echo cancellation coverage for that hardware without an EC module installed. That is kind of vague since that platform went end of support almost 6 years ago.
Dealing with old equipment does make things harder...
