Configuring ATM\IMA back to back
darrtech001
This is purely for lab experimentation. I'm trying to configure atm\ima in a back to back configuration. The int are up\up but cannot pass traffic.
UNGROUPED CONFIGURATION:
Router A
interface atm 1/0
no ip addr
no atm ilmi-keepalive
interface atm 1/0.1 point-to-point
ip address 192.168.1.10 255.255.255.0
atm clock internal
pvc 1/35
protocol ip 192.168.1.20 broadcast
Router B
interface atm 1/2
no ip addr
interface atm 1/2.1 point-to-point
ip address 192.168.1.20 255.255.255.0
atm clock internal
pvc 1/35
protocol ip 192.168.1.10 broadcast
GROUPED IMA CONFIGURATION
R1
interface ATM1/0
clock source internal
no ip address
scrambling-payload
ima-group 1
interface ATM1/1
no ip address
scrambling-payload
ima-group 1
interface ATM1/IMA1
no ip address
interface ATM1/IMA1.1 point-to-point
ip address 12.12.12.1 255.255.255.0
pvc 1/100
protocol ip 12.12.12.2 broadcast
R2
interface ATM1/2
clock source line
no ip address
scrambling-payload
ima-group 1
interface ATM1/3
clock source line
no ip address
scrambling-payload
ima-group 1
ip address 12.12.12.2 255.255.255.0
pvc 1/100
protocol ip 12.12.12.1 broadcast
What am I missing in the config???
Thanks Much
5 Replies 5
paolo bevilacqua
Should work, you can take "show ima interface atm 1/ima1 detail" to see what's going on.
Note you don't need "protocol ip x.x.x.x" with p2p subinterfaces.
Something is definately missing from the config, because even with static routing - nothing is getting over the atm connections.
Check and post output of above command first.
p.bevilacqua, thank you for taking the time to help me out on this issue.
I decided to break the config. down to the most basic elements and go from there ..... and bam!!! lol! Got it working.
I also discovered, that for some unknown reason, if the module has atm links in waiting {No config. but up\up} .. it won't let configured int. come up. So I had to shut down all int. that didn't have a config. VERY STRANGE!
I'm using NM-4T1-IMA & NM-8T1-IMA modules in 2651xm routers.
Non-IMA Configuration WORKING!
R1
interface ATM1/0
no ip address
interface ATM1/0.1 point-to-point
ip address 10.10.10.1 255.255.255.0
pvc 1/40
encapsulation aal5snap
protocol ip 10.10.10.2 b
R2
interface ATM1/2
no ip address
interface ATM1/2.1 point-to-point
ip address 10.10.10.2 255.255.255.0
pvc 1/40
protocol ip 10.10.10.1 b
R1
interface ATM1/0
no ip address
ima-group 0
interface ATM1/1
no ip address
ima-group 0
interface ATM1/ima0
no ip address
interface ATM1/ima0.1 point-to-point
pvc 10/100
R2
interface ATM1/2
no ip address
ima-group 1
interface ATM1/3
no ip address
ima-group 1
interface ATM1/ima1
no ip address
interface ATM1/ima1.1 point-to-point
pvc 10/100
Again thanks much
Please see the attachment for the full config & verification efforts.
